Jumping waves trouble!
Old 05-23-2012 | 11:01 PM
  #31
Originally Posted by Von Bongo
The one that was over by I think Hawks Nest for a while on 54?
no idea berry owned it he worked at kellys port for years it was on the kellys port lot he ran it all summer in the support are troops run and shoot out run.
Brett
black thunder 46 is offline
Old 05-23-2012 | 11:58 PM
  #32
Default wave jumping and blowout
BT46,
I'm asking about your set up to assist me in my rebuild,
are those 23's mirage plus ?
what kind of drives?
what are the engine center-lines?
what is the prop shaft height set at.
i have an 84 30 scarab
I'm sticking w/ my TRS drives
my engine center-lines are 34"
i read a thread on here that TRS liked to be between 4"-5"
prop height, on old straight V hull, but now i can't find the thread!
hopefully i'll be safe 4.5"
again, not here to tell you how to drive, or whatever the heck happened to this thread. just here to learn some so i get it pretty close the first time.
good luck getting the bullet dialed.
thanks
dan
outonsafari is offline
Old 05-24-2012 | 07:28 AM
  #33
here we go again.... griff thanks for all the help youve given me over the past year.. TEX.. hitting pot holes with your trailer does not constitute rough water.. i tried 3 blades on my pantera twin and i ran into the same problem as your having brett. i run B1 26's now and i have a set of 24 and 26 hydros to try out if i ever find the time. you can email me the pics of your bullet and i will throw them up for ya.
[email protected]
88bullet is offline
Old 05-24-2012 | 12:53 PM
  #34
Originally Posted by outonsafari
BT46,
thanks
dan
Yes on the props and brovos. My 40 fountain runs 3 blades but I only ran it once in 2 years do haven't tested props yet.
Brett
Old 05-24-2012 | 12:54 PM
  #35
[email protected]
That would be great!!!!!!! Thanks
Brett
Old 05-24-2012 | 02:30 PM
  #36
TEX.. hitting pot holes with your trailer does not constitute rough water.. [email protected]
WTF are you talking about? Your three pantera's have seen nothing but pot holes since you've bought them.
TexomaPowerboater is offline
Old 05-24-2012 | 02:35 PM
  #37
Originally Posted by black thunder 46
He helped me pick out another ass hole on the site
Brett
Probably not a good idea to be jumping wakes in the first place. Good way to tear up a boat real fast.
Old 05-24-2012 | 03:06 PM
  #38
Originally Posted by Griff
"People like me" have helped more people OSO with good advice and made more lasting freindships than you will ever realize. BTW, I have never even met Brett personally. I have seen him driving several boats and watched him dock a 46 BT in places and conditions that I would be nervous in my 32 AT.
I never called you "phucking azzhole" or any other names and am mature enough to not have to go there.
Yeah Griff, your comments regarding my rough water seat time were real mature considering you've never met me or boated in my pond. You started it Griff, so its fair game.
Are you telling me if I told you my buddy has more rough water seat time than you do on the toilet you wouldn't consider it a personal insult? LOOK Griff its raining!!
Old 05-24-2012 | 03:37 PM
  #39
OldSchool's Avatar
Man, WTF is wrong with some people????
Does every phucking thread on OSO have to go to the chitter now? (Shaking my head)
Brett,
I have some experience with 31 Bullets
Mine came with a 27 Mirage Plus 3-blade on it and i switched it over to 26-pitch 4-blades. It picked up about 4-5 mph at cruise and didn't lose anything at full speed. So, most of the advice given is good that you've received. What I have never seen is a 31 Bullet that came with a high X on it. So, unless someone has raised the x-diminsion, a high x is not the source of your problem. My Bullet was the easiest boat to drive that I've ever been in. Get it on plane, trim it and go. No tabs needed unless there was a big wind going on.
I sure miss my Bullet!!!
OldSchool is offline
Old 05-24-2012 | 03:41 PM
  #40
onesickpantera's Avatar
It appears that most do!(also shaking my head)
Tex, are you seeing a pattern here? Because I am.
onesickpantera is offline
