Originally Posted by socalstone
(Post 3697528)
I hope that is true.
Originally Posted by SHARKEY-IMAGES
(Post 3698284)
Buck |
Dustin:
I know you are a man of your word and I now believe that the ECM and the 600sci is unmodified and in its trim that Mercury Racing delivered to OuterLimits. I think we all realize that the 600sci is really about about 660HP at the crankshaft and with that power the boat is performing in awesome fashion. As I and many others have said the new technology and construction methods in this boat are incredible state of the art and the results show it works very well and as I said it gives the rest of the performance boat building industry a preview and example of what the new technologies and designs can do for hull performance. As for the cabin , there's limited height in the cabin from reduced hull height and that is obvious when one sees pictures of the boat in the water next to performance boats with taller freeboard. This lower profile and freeboard obviously reduces the overall weight of the boat and aids the aerodynamics at speed. This is a cutting edge boat with a great future for those who seek this type of performance boat and those that can step up to the cost of this technology and build quality. Again, Kudos to OuterLimits for there new SV29 offering and I wish them much success and a great future with this boat! I am a believer, I just can't afford one! Best Regards, Ray @ Raylar |
Structure and Design
Now I can show the images that reflect how OL utilizes the frame work to not only support the hull but also makes up the cabin. It is my understanding this is a component from the larger grid system used in the larger OL therefore a cost savings being able to used the same grid for "all" boats ... Take note where you see a flat black finish ... http://sharkeyimages.zenfolio.com/im...89399974-4.jpg http://sharkeyimages.zenfolio.com/im...67485829-4.jpg http://sharkeyimages.zenfolio.com/im...73375112-4.jpg |
Is it me or it kinda looks like half of a cat with the transom cut out like that? Maybe thats why its so fast.
Originally Posted by Whipple Charged
(Post 3698822)
Again, it is.
Do you know the deadrise at the transom? just curious if less than 24. |
Originally Posted by Expensive Date
(Post 3699038)
http://sharkeyimages.zenfolio.com/im...12264152-4.jpg http://sharkeyimages.zenfolio.com/im...71150678-4.jpg |
Tim nice work !
Tim:
I did, read #4 on my first post about the aero package where I mentioned nice rear corners. This is all part of the aero package and I would not be surprised to hear they used models in a wind tunnel test for the shaping. Best Regards, Ray @ Raylar |
A gorgeous boat for sure. I am looking forward to going home again (grew up in Mass and RI). I will be stopping by OL if my wife likes it or not. Not to buy, just to gawk.
I would think they use CFD software for the Aero stuff. Windtunnels this size are hard to come by and very expensive. 1/10 scale models in small tunnel's can and have been used on boats.
They (Outerlimits) have a designer with an aircraft background so his best practice's will most likely not include any high wind drag design's. In playing with our redneck windtunnel (boat beached at desired running angle big block airboat making 95 MPH wind) we have some basic data. We have also been lucky enough to have a really good friend who is good with CFD! Many thanks to the windtalker for his help with our SVL! Steve |
(Post 3699038)
speaking of that overhang, is that included in the 29' length? or not. still not clear on overall length and/or length from tip to transom |
(Post 3699310)
that is a lot of overhang. I see what your saying, but the cats all run fast because they pack air up front which lifts the boat up for less drag.
Originally Posted by GRH
(Post 3700152)
Its a 26' boat with 3' of swim platform... I'm looking forward to seeing them enter the Manufacturers P-4 class with one...
Originally Posted by Mastercraft240
(Post 3700203)
False.
(Post 3700341)
Sorry mate.... but its got a 26' running surface....
does the overhang (bussel) create drag, lift or niether.... on any boat???? I'm sure this has been discused somewhere before here just haven't read it.
(Post 3700353)
You saw the trailer. You MUST know what the running surface then! Lol what a genius you are, sir.
Q,
Why didn't OL use an ITS transom assy? Just curious.... |
I'm curious about the deadrise of this boat as well.To me it looks like between 20-22*at the transom.
Does the boat have a constant deadrise or variable [warped] ?Specs seem to be top secret on these,lol. |
Originally Posted by Dean Ferry
(Post 3700364)
Q,
(Post 3700361)
and you have a smart mouth.....
Originally Posted by spectras only
(Post 3700373)
(Post 3700404)
You're trying to state facts that you heard from an unconfirmed third party. There's no possible way your going to know the exact running surface from looking at a trailer that hasn't been fit for a boat. I've put a tape measurer to that boat and it's 29ft and change of running surface.
(Post 3700364)
Q,
The aerodynamics certainly play a large part as speed increases, as everyone who has taken flying lessons learns early on in ground school, that as speed increases wind resistance doubles.
Do a google search for NACA. You will find a lot of the test results from back in ww2 on till they became NASA. Noticed that in the past few years more boat builders are using a variation of a naca duct rather than a hood scoop. I read a test on a couple of pontiacs in one of the car magazines a long time ago, same power, one with the standard hood, the other with the fancy hood scoop, top speed was 5-10 mph slower for the one with the hood scoop. In bullet ballistics, boattail (sic) bullets maintain more energy/velocity at distances than flat base bullets, check any of the bullet manufactures reloading manuals or visit their websites. In all testing from naca/nasa to bullet manufactures they have found that the rear end is actually more important than the front end. Closing the stream of air neatly reduces the vacum affect caused by the object passing through the air, to put it simply. I have read test's that showed a flat front bullet with a tapered rear-end performed better than a tapered front end and flat rear-end. Now that engine technology has pushed boat speeds to the point that aerodynamics plays a much larger roll, what has been used in airplanes, bullet development and race cars will become the norm in the boating industry. Why not take advantage of Bernoulli's principle and allow the deck configuration to produce lift just as cats produce lift. Every time I see a boat with big hood scoops, my first thought is, there's some unnecessary drag. Perhaps they want to impress the bikini wearers with their big hood scoop! |
1 Attachment(s)
does this help you find them??
:lolhit:
Thanks for the pic |
:poopoo:
(Post 3700411)
Unless of course the guy that built the trailer told me so......
thanks for the explanation SinOjos...and for the record, I do believe that one or more big scoop attract a nice pair or two:evilb:
(Post 3700458)
Its amazing what heresay there is here. The boat is 29'-11" with the 13" bussel included. Thats the facts.
Those trim tabs look about 18 to 24" ??? http://sharkeyimages.zenfolio.com/im...72127039-4.jpg |
Without being upside down, I waited for the lighting to be just right to capture the details of the steps in the bottom and pad:
http://sharkeyimages.zenfolio.com/im...10281840-4.jpg |
Originally Posted by lil red
(Post 3700451)
Would you have anymore hi-def pics of the boat upside down? I can't really make this out, but it seems that the deadrise angle is variable as you move towards the transom. Any more upside pics like this? I'd like to continue our technical discussion onto our next planned topic: " OL S V29: Hull Design Analysis " . |
The others I have are blurry, see what I can put up later
Sharkey, This is an awesome pic! Can you change the contrast so that we can see the details of the bottom? .
(Post 3700463)
Originally Posted by SinOjos
(Post 3700446)
Do a google search for NACA. Every time I see a boat with big hood scoops, my first thought is, there's some unnecessary drag. Perhaps they want to impress the bikini wearers with their big hood scoop! Here's my 1999 > http://www3.telus.net/spectrasonly/viper%2005.jpg |
(Post 3700458)
(Post 3700446)
P-51 is a prime expample. I suppose the big scoop is what allowed those pilots to do well with the ladies. :hijack: http://www.pietschaircraft.com/galle...craft/p51a.jpg Now if Romer would just cut the scoops off his skater he probably could be Top Gun this year! |
Dustin , i superimposed the stern image of my 24* deadrise boat to the OL's and it seems to have a 22*.Am I right ? Just want to get the cat out of the bag.
| All times are GMT -5. The time now is 07:14 PM. |
