Do I need exhaust bellow?
Old 07-20-2012 | 10:23 PM
Default Do I need exhaust bellow?
I was think about this and was wondering if I needed an exhaust bellow? I would like the louder sound so that wouldn't be a problem.
jbizub5192 is offline
Old 07-21-2012 | 12:14 AM
J-Bonz's Avatar
Assuming you have a Mercruiser.... One word, No.. You dont need it
J-Bonz is offline
Old 07-21-2012 | 01:28 AM
Default fixx
its their for a reason,,if theirs exhaust coming out of the hole in the transom the heat could soften the ujoint bellow and could end up with a hole in it,,your judgement call...
FIXX is offline
Old 07-21-2012 | 08:58 AM
You can have a short bellows section coming out of the gimble. No worries about burning the ujoint bellows, its in the water.You can add a small turn down if you are worried about that. My boys have it set up like that on their 20 ft., no problems
inthetundra is offline
Old 07-21-2012 | 10:09 AM
J-Bonz's Avatar
I guess I should restate this. You dont need the exhaust bellow. You can use the straight tube that only gets connected on the gimbal housing
J-Bonz is offline
Old 07-21-2012 | 09:28 PM
Ok thanks, i didnt think i needed it but wanted to make sure. Does running it without bellows make it sound a little better/louder? I know it will not sound like a thru-hull exhaust but maybe in between thru-hull and through the sterndrive? I think i might cut the exhaust bellow in half so it is a little away from gimbal housing.
