Fountain 29Fever -Goods & Bads >
Old 07-26-2012 | 10:21 AM
Sea-Dated's Avatar
Originally Posted by Too Stroked
Something that nobody's mentioned is how low the stern of a 29' twin sits. The rub rail is literally in the water.
Good point
Mine had twin big blocks so I am sure a single would sit a little higher.
Sea-Dated is offline
Old 07-26-2012 | 10:29 AM
Indy's Avatar
Member #154
Originally Posted by JRider
Remember this is a Fountain...not really a 29...more like a 26 with a beak and a platform. 26' boats run great with singles
If you look at a transom shot of a 29 there's a notch as well as a swim platform. Add the beak in and you probably have a 25.
Is the transom deadrise even 24 degrees?
Indy is online now
Old 07-26-2012 | 10:31 AM
I had a 89 with twin 260's and Alpha's. I put over 500 hours on it and never broke once. It was only a 60 MPH boat! It was originally called a 27 then miraculously grew 2 feet.
Brad is offline
Old 07-26-2012 | 10:47 AM
Too Stroked's Avatar
Originally Posted by Sea-Dated
Good point
Yes, the single actually looks "normal" at the dock.
Too Stroked is offline
Old 07-26-2012 | 10:49 AM
If memory serves me correctly, even the "big" Fountains (35' & up) were 23 degrees. The 27' - 32' models were something like 21 or 22 degrees. The CS 24 was, well let's just say it was almost flat.
Old 07-26-2012 | 11:12 AM
LOL...I was being generous! Fountain guys get sensative about their length!
JRider is offline
Old 07-26-2012 | 11:24 AM
Big Time's Avatar
Originally Posted by gladhe8er
my brother, "big time" had an 03 w/525. It ran 79-80 and was a good 6-8 mph faster than my boat in calm seas(1 foot or less). Once you got to 2 footers, i was walking by him as he was getting beat up. Its a good lake boat, not a great rough water boat.
wrong!!!!
Big Time is offline
Old 07-26-2012 | 12:36 PM
I was so set on buying a 29 fountain single engine before I joined this site and really did the research. Up until that point all research was from magazines. Couple of things that killed it for me was: cabin was too small and not enough headroom, the idea of a hand laid solid glass hull (no core) custom boat vs production., I wanted a true 28-29ft hull, didn't like the transom rubrail so close to the water line.
I agree with other post about maintenance of single vs twins. In the long run it was a wash IMO and I valued the reliability of twin stock power and drives vs single high performance with the obvious possiblity of drive problems that comes with all big powered single engine boats over 27ft. You can rebuild or replace twin stock 502's for the less than it will cost to rebuild or replace a 525EFI. I ended up buying a 28 Apache and was a home run for our family. Sold it a month ago.
TexomaPowerboater is offline
Old 07-26-2012 | 02:17 PM
Lol. But really if you take the swim platform and the first 3-4 feet off of any boat you could really say the same.
soldier4402 is offline
Old 07-26-2012 | 02:30 PM
Not all of that was a Fountain issue. The USCG changed the way they required manufacturers to measure boats with built in swim platforms about then. Silly things happend at Fountain and other manufacturers because of that. For instance:
- The 10 Meter became a 33' (square transom) that became the 35' with a molded in platform
- The 12 meter that became a 40' (square transom) became a 42' with a molded in platform
- The 27' square transom became the 29' with a molded in platform
- The original 29' (square transom / twin engine) molds reportedly were pushed back into the burning building when Fountain had a fire at the factory because Reggie hated the hull so much
