air pressure
Old 10-23-2012 | 11:15 AM
I would let 1 psi out of the other 5 and add 10psi to the low one to compensate for damages!
or
sell the trailer and us this method.
Attached Thumbnails air pressure-redneck-towing-speed-boat-top-pickup-truck.jpg   air pressure-drunk-boaters.jpg
phil_p999 is offline
Old 10-23-2012 | 11:19 AM
Wobble's Avatar
SORE MEMBER
Originally Posted by mike tkach
now im worried that the drag caused by the low tire might have ruined one of the ball joints,im afraid to drive the truck to the ford dealer ,should i get it towed in?
Most Ford trucks do arrive at the dealer behind a tow truck so I am thinking that should be the most reliable way to get there
Wobble is offline
Old 10-23-2012 | 11:50 AM
This could have been easily avoided had you checked the level of your blinker fluid reservoir. This is page one of every owners manual.
Sunny32SSR is offline
Old 10-23-2012 | 11:56 AM
sommerfliesby's Avatar
This thread belongs in the hall of fame.
sommerfliesby is offline
Old 10-23-2012 | 12:11 PM
Have you rotated the air ? Sometimes this will helps.
ed
Interceptor is offline
Old 10-23-2012 | 12:15 PM
Steel trailer or aluminum? If it was aluminum, the extra flex on the hull from lack of support most likely caused your stringers and bulkheads to warp. Might as well have them all replaced over the winter so there are no surprises next season.
RT930turbo is offline
Old 10-23-2012 | 12:30 PM
I heard a long time ago that if the little lady gets D cup implants that it reverses any and all ill effects.
This also worked for us on a forgotten password.
Good luck and keep us informed.
Back4More is offline
Old 10-23-2012 | 03:28 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Did you re-air all tires with a hand pump and winter air . Air is more stable when hand pumped . Make sure you install an inline moisture scrubber before pumping or you'll fock up the whole process .
the deep is offline
Old 10-23-2012 | 04:05 PM
Also, don't use salt air. Always use unsalted air.
Old 10-23-2012 | 04:20 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
If you only trailer for a couple miles each way, you should be ok.
No need to pay $0.50 for the air at the station, put that $$ in your gas tank.
US1 Fountain is offline
