Lake Levels in 2013...
Old 12-11-2012 | 07:31 PM
Originally Posted by chrisf695
I know its only early December... but looking at my lake(Inland) being down 2.5ft... Im a little worried that here in MI that the levels aren't really going to improve that much over the winter... I know I might be ok in the spring or the first half of summer... but I thinking i may have a really short season next year because of this...
Anyone feel the same?
Lake Ontario just hit a 50-yr low, with all of the great lakes expected to be at record low levels by April. Not good for Spring boating.
Donzi ZX is offline
Old 12-11-2012 | 08:22 PM
GAZ
My home reservoir Blue Mesa Reservoir, largest body of water in Colorado (only 9000 acres) Sixty miles west of the Continental Divide is over 70 vertical feet down from full pool. The second lowest it has ever been since the dam was built in 63.
Right now we are started on a real crappy snow year if we don't get ALOT of snow soon We won't have much boating here. Or irrigation water.
GAZ is offline
Old 12-11-2012 | 10:06 PM
This season I barely made it out of the marina for final haul out in October. The water is so low that the big rocks in the channel caused 8 bent prop blades. If the water level doesn't get better, half the boats in the marina cannot get in or out next season. As it is in the start of the season on Lake Ontario there were places I had just 6 inches to play with and not worry about rocks.
One of the other boats bought side scan sonar and put it on the small tender to mark rocks for next season.
Perlmudder is offline
Old 12-12-2012 | 08:08 AM
Smitty's Avatar
Water levels across the U.S. are all down. Question is, where did it all go ?? There is a pretty set amount of water on the planet. It just gets moved around in cycles.
Smitty is offline
Old 12-12-2012 | 08:51 AM
TEAMBAJA's Avatar
Probably sitting on shelves called bottled water. This may sound stupid, but any time I see someone throw away a plastic water bottle with water in it, I cant help but think its probably stuck in there forever.
TEAMBAJA is offline
Old 12-12-2012 | 09:10 AM
THEJOKER's Avatar
Yea Lake Lanier is going way down this time! I move my dock out every Wednesday!
THEJOKER is offline
Old 12-12-2012 | 10:25 AM
Dean Ferry's Avatar
Veteran: Air Force
Let it snow and rain EVERYWHERE All of the lakes and rivers that we use here in Fl. seem to be full. And of course if we boat in the ICW, it's always at sea level.......
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 12-12-2012 | 11:48 AM
Here in PA, our lake got low enough at the end of the season that I was barely able to get on my trailer at haul out time. However, we've had a lot of rain thru the fall plus Super Storm Sandy so we are back to normal I believe. Fingers crossed for the Spring and for everyone else across the USA.
MonkeySea2 is offline
Old 12-12-2012 | 12:14 PM
Boo Hoo ...you guys are complaining about 2.5 ft , Lake Mead is down over 101 ft right now ! We need snow in the Rockies !
HALLETT FAN is offline
Old 12-12-2012 | 12:15 PM
Indy's Avatar
Member #154
Here in CT we get in the mid 50s for inches in precipitation for the year (snow/rain). We're 20 inches behind in rain. It doesn't rain here anymore...even that stupid hurricane that ripped our area didn't dump much rain, just wind and water piling up.
We're pumping pretty much sediment in our well the past month, I suspect there's going to be some serious water issues soon. We have miserable weather, but it's mostly drizzle that has no accumulation.
Indy is offline
