View Poll Results: Bravo XR drive breakage
Broke upper gear set
72
82.76%
Broke lower gear set
15
17.24%
Voters: 87. You may not vote on this poll
#61
Thanks, but I am not known to be "poltically correct" . I call it as I see it. However, if a 525 is questianable, how come Merc even offer it as a choice? fully aware that there is an issue. How many XR bolted to 525's? as a standard package? It's in their brochure, not just some buyer wants more then it's designed for. Just my .02
Come to think of it, I have seen HP limits on the Bravo XR drive but do they publish a weight limit or recommendation?
#62
[QUOTE=Keith Atlanta;3836326]For what its worth, I wasnt trying to call you out. Actually, I agree with you but twin 525's through XR's in a 6500 pound boat is doable and pretty solid. On the other hand, I have seen a few 42 or even 51 foot boats with triple 525's or 600s thru Bravo XR's... I would hope Mercury never intended that combination. QUOTE]
No worries Keith. I didn't take it that way. We value your input and oppinions, politically correct or not.
#63
I dont even want to take it out anymore as I broke 3 maybe 4 times the upper's and crap ends up trashing lowers, to upgrade to anything else is a total waste since the boats value is less than a 1/3 of what it cost to put it together. I think the original Bravos were stronger than the XR's and faster too. If you drive it like it's a pimp mobile they work but anything over 5 g rpm's your asking for it.
#64
#65
My buddy bought the original OSO Top Gun and put 300+ hard hours on it without a single issue (headers nor drives, 525/XR boat). He always felt the standard length XRs were better than the shorties for durability. Drives came off the boat at 275 hours for service and I think at that point they got swapped when put back on (swapped as in rotated).
#67
Couple things boys. I have a 1994 STD Bravo.. 500+ hours with a 454 mag. No problems. none, But no serious HP and high revs. However. The XR's problems are not in the gears. It's in the overall design specifically in the upper driveshaft. Some time ago (not sure when) merc changed the upper niddle bearings and also hardened the driveshaft etc. Now. You got more "niddles" in the bearing but less of them. Also the port wher the lube gets to the bearings and shaft is too small. So the niddles/bearing digs a groove in the shaft and stuff gets out of alignment, viboratin then failure. Merc. wont tell you this, but I have discussed this with merc racing staff and during some "casual" talks they will admit it. I am pissed at Merc also, so I have no reason to keep it out of the arena. I had great relatinship with Merc, untill the CMI issues. (old stuff). I had both the 525's XR drives upper shaft replaced, seen the problem but I cought it in time so no break downs, to date. Close. The gears are not an issue. Change the niddle bearing to the old style, if you can get them , machine the lube hole out to get more oil in the bearing and shaft areas and the XR will last longer. (unless you bolt on some 850 HP crazy stuff.
I will see if I can dig up the driveshaft pictures one of these days. But at the end of the day, it's called planned obsolesance, faulty parts, designs, more new parts and service sales. Merc's integrity is gone long ago.
I will see if I can dig up the driveshaft pictures one of these days. But at the end of the day, it's called planned obsolesance, faulty parts, designs, more new parts and service sales. Merc's integrity is gone long ago.the older bearings are needle bearings( more needles)
You can still get the needle bearings....I use the needle
bearings whenever I'm into one.
I think that I've only had 1 or 2 clutch shafts that had issues,
but I've dealt with about every scenereo of upper gear
failure multiple times, and these were behind 575's and below.
#68
The new bearings are a caged bearing ( less needles)
Whose fault is that?
#69
Smitty,
My ITS XR drives are with Mr Gagets. I just sent them to him to refresh before they break again. he found that 1 upper gear set was pitting. Are you going to have your new gears ready any time soon?
#70
TROPER
At this time, looking at 6-1-2013 release date. No guarantees on that date....
