bottom cleaning...
Old 04-29-2013 | 08:12 AM
On/Off if the boat is really hit..
For general upkeep, you can't beat Slimy Grimy.
Madman7 is offline
Old 04-29-2013 | 08:19 AM
lucky strike's Avatar
Norlo toilet bowl cleaner , Mary k, it's all the same stuff basically
Use rubber gloves & a paint brush after you spray it on
lucky strike is offline
Old 04-29-2013 | 08:55 AM
Originally Posted by Perlmudder
on off acid works great, but sucks to work with it. Muriatic acid will do it also. Neither are very good for your boat.
Why do you think they are not good for you boat? They come in a PLASTIC bottle Your boat is basically made of plastic.
4bus is offline
Old 04-29-2013 | 09:09 AM
wstultz's Avatar
Social Distortion
Are any of these cleaners bad for Aluminum? I only ask because mine sits on an aluminum Myco and I would be sad if they some how tarnished the trailer.
wstultz is offline
Old 04-29-2013 | 09:17 AM
scarabman's Avatar
Definitely will stain/etch aluminum. Cover the trailer beams with plastic, or wet the trailer first.
scarabman is offline
Old 04-29-2013 | 09:18 AM
it all depends on what you trying to get off? the carpet moss?
or the brown stain ? what.
the brown stain can be WIPPED off with iron out, and water. (int he pluming section of walmart.)
mittens is offline
Old 04-29-2013 | 10:01 AM
ziemer's Avatar
Originally Posted by TWIN-SPINS
http://fountainofyouthrestore.com/Fo...outh_Home.html power-one,,,50/50 w water spray bottle,,,works greats
Another vote for Power One... I used it on mine last year with great results. Works just as good as acid, but with the chemical burns!
ziemer is offline
Old 04-29-2013 | 10:06 AM
POWER ONE! Enuff said.
low_psi is offline
Old 04-29-2013 | 10:33 AM
Haha. Have you ever tried putting it in a cheap spray bottle like windex? not a good outcome. The stuff works great, no work required, but then you have to wax everything all over again. I was once day working on a 130 at Bahia Mar in Lauderdale and they wanted me to clean the tiny enclosed lazarette with it. I said, sorry man, I don't get paid enough for that.
Perlmudder is offline
Old 04-29-2013 | 03:25 PM
fabin61's Avatar
+1...If it is a serious stain, buff out with diamond cut and then apply Leverage wax. I get compliments all the time for my '97 Baja.
fabin61 is offline
