bottom cleaning...
Old 08-21-2013 | 04:10 PM
anewway's Avatar
Originally Posted by Keith Atlanta
http://www.goofoffstainremover.com/p...allon-gsx00101
You can easily get it at Home Depot $9 gallon. Literally spray it on with a bug sprayer and come back 5 minutes later and hit it with a hose.
Perfectly white and 10x cheaper than any marine product....
Which cleaner did you use? The link goes to the main Goof Off page. The outdoor rust remover maybe?
Thx
anewway is offline
Old 08-21-2013 | 06:18 PM
BillR's Avatar
OSO Moderator
[ATTACH=CONFIG]506738[/ATTACH]All acid based cleaners damage your gel coat. Do research!!!
Use Ring-go to clean bottom and keep your gel coat damage free. Also - search Ringo here on OSO.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-21-2013 | 06:21 PM
Originally Posted by low_psi
POWER ONE! Enuff said.
It's pure magic! Best I've ever used, and you can put it on with your hands.
RT930turbo is offline
Old 08-21-2013 | 07:27 PM
4195's Avatar
Can You Hear Me Now??
Bill I searched for where to buy this stuff but could not find it. Can you point me in a direction.
4195 is offline
Old 08-21-2013 | 09:36 PM
Item # RINGGO
A concentrated 23% hydrochloric acid disinfectant bathroom toilet bowl cleaner, especially formulated to kill many germs. Dilution: 3 oz per 3/4 gallon of water. White emulsion/acidic/pH: <1/USDA: C2/NSF listed. 12 per case. Kills many germs commonly found in hospital, industrial and institutional environments. High acid level with acid compatible detergents facilitate the removal of resistant stains (rust, hard water deposits).
Same product ?
Interceptor is offline
Old 08-22-2013 | 05:16 AM
By far the best hull cleaner I have used is called Captain Phab.
RG.
Rick G is offline
Old 08-22-2013 | 05:33 AM
Oxalic acid works very well. Mix 1/10 with water and spray the mixture on the hull.
badluck is offline
Old 08-22-2013 | 06:43 AM
I can't speak for everyone on here, but I have learned from my mistakes. I will never put any kind of acid based cleaner on any of my boats again. It removes the wax causing the stains to apear more frequent. Even if you wax the fiberglass after cleaning.
If a little research is done, or maybe talk to someone in the fiberglass boat building profession. They can confirm this. The mold for fiberglass is waxed then the gel coat is put in then the fiberglass. The mold it then removed from the whatever (in this case a boat hull) it is polished out and finished. The wax from the mold is still on the hull and acts like a protective barier. Over time when acid is used for cleaning it removes the wax and etches the gel coat. Even if you rewax the hull it will never be like it was when it came out the mold.
I am not a professional this is just what I have learned and my option is never to use acid base cleaners on my boats again.
BoatnBrad is offline
Old 08-22-2013 | 06:48 AM
Then what do you use?
Crude Intentions is offline
Old 08-22-2013 | 07:25 AM
Sorry for got to put that. It is basicly a acid free bathroom cleaner that is safe as liquid dish soap. no wories about protecting trailer, concrete, etc. it is safe for alum., copper, brass, glass can't use it on marble don't know why don't have any to worry about. lol. It is called Pro Chem Enviro-Clean RTU.
