Building the new/old school larry smith 26
#143
Hey Dan Great talking with tonight
Thanks again for letting me try that prop
What is the determining factor when choosing the tab size and location ?
Also you mention the balancing of the boat i'm guessing your referring to the CG ? If so where are you placing it ? Mines 87" from the transom about 10" in front of the harmonic balancer
Again trying to sort out this 28' single engine big HP #5 drive with a two speed
thanks again
thanks again
#144
I have a 27 speedster,,,,that came with with 22" tabs on it
and tabs were too touchy on the small deep vee hull
1 tiny bump on 1 and boat jumped to side,,,,too hard to fine tune and agrivating
nothing more agrivating than keep bumping tabs to get right spot
even tried 6 volt reducer to slow down pumps
cut off 6" down to 16" and lots better at 40-70 crusing speeds in some slop
nothing worse than boat changing drastically with a milisec bump
long tabs on short boat,,,,,,
btw ,,,,did a great job on the speedster
#147
#148
