Why Center Console's???
Old 02-20-2014 | 09:00 PM
  #121
Originally Posted by Jupiter Sunsation
I think he was trying to show that the CC's weren't the first to the dock.......as the faster boats usually are.
I would file that as common sense. I also would say that was not his point..... His point was more of "look what boats aren't at the first stop".
Don't need to be first. I have friends with boats in that pic I will gladly pay for gas for if that's my desire. I am fine with comfort and middle of the pack.
Nate5.0 is offline
Old 02-20-2014 | 09:04 PM
  #122
Yeah but didn't you admit a few pages back that you just bought this boat and haven't used it much? How about filling the tanks, go for 100 mile run, get back to the dock and refuel then do some math......Your post is very similar to the guys with diesel pickups sitting on 22.5's, with tons of performance mods and they brag they get 22-25 in city driving pulling a 10K trailer! ..............I suspect they can't do simple math!
I haven't used it at all. It is 2000 with 2006 motors. The previous owner had it for close to two years, so I am pretty sure he had enuff wheel time to get an approximation on fuel usage. I am going off of the previous owners info and another concept owners who boats on the same water as I do and is on this board. I don't understand why it is so hard to believe a boat with efficient outboards that only weighs 4800lbs can get good fuel economy. I guess it's easy to be skeptical.
low_psi is offline
Old 02-20-2014 | 09:59 PM
  #123
Originally Posted by Nate5.0
If I am building a CC while like the I/O feature I really want the O/B in the shallows around the islands.
I get around the shallows in the bahamas just fine with my bravos. I can run in 18" of water no problem as long as I keep the speed up and trim up a little. At idle I need about 28" but the hull hits before the drives.
pstorti is offline
Old 02-20-2014 | 10:39 PM
  #124
Nobody is trying to be a jerk here but look at the numbers for yourself on http://www.mercurymarine.com/engines...sts/outboards/
The single engine bass boats get 4mpg, can you get 3 mpg in the right conditions maybe and yes that is great for outboards but it is a long way from 4 mpg.
Your boat was tested but they only show the speeds but you can look at the fuel burn on the other tests at 3000 and 4000 rpm and get 10-12gph at 3000 and 17-20gph at 4000, that gets you 2.6-2.8 somewhere in that range. If you are really doing much better good for you that is great but unless you have smart craft or something else giving you gph and a gps you really don't know.
pstorti is offline
Old 02-20-2014 | 11:18 PM
  #125
The shallow water thing has me confused. Unless your on a jack plate an outboard lower unit is very similar to an outdrive lower unit. You can trim an outdrive up in shallow water also. Outboards on a jack plate or not and outdrives will generally trim up above the hull bottom anyway so your still limited by the v bottom.
For the room I understand. Cleaning is about the same as both have vinyl and fiberglass to clean. The biggest difference in cleaning would be in the engine room and I get that.
Crude Intentions is offline
Old 02-20-2014 | 11:55 PM
  #126
So let me get this straight ... 0 time on the boat but the guy who was trying to tell sell you a boat told you 4mpg so then it must be true.
Oh man there`s one born every minute
btw, "how many did you catch today"
ICDEDPPL is offline
  #127
Center Councils are for LOOSERS, WTF
tommymonza is offline
Old 02-21-2014 | 12:10 AM
  #128
low_psi is offline
Old 02-21-2014 | 12:30 AM
  #129
Real intelligent. Great spelling.
low_psi is offline
Old 02-21-2014 | 06:01 AM
  #130
I love how butthurt everyone is on both "sides" of the debate. It's a boat, get over it. For some, a center console is a lot better fit than a good ol' go-fast. It's as simple as that.
SnailblazerSS is offline
