Season over....tossed a rod...
#111
http://www.aera.org/ep/
This just came today; read the article on Optimization of clearance design for high performance engine bearings. Maybe should start a new thread on engine bearings and clearances.
#113
You cant hold a gallon + of oil in the top of the motor, I dont think you sucked it dry unless your oil level was very low. Does it say which journal this was on?? if you were starving for oil it'd be the last one, but the others would show signs of heat as well..
#115
Good to know about the pans. Stock 6 qt pans gave me issues when running hard in rougher water, stock 8qt pans hit my offshore mounts so I bought 10qt Hardin pans. Found out this year canton makes a nicer pan for less $$$
#116
Tim,
I keep reading "I am only making 600 hp" which sure, isn't a ton in the offshore world by any means, but..... You are driving this thing all day in the meat of the torque (4500 rpm) pushing a heavy, wet running ride with deep legs on long cruises. Guys with bigger hp rarely hold it there all day. I know you are on a budget, but if you are going to continue to run your boat that hard all times you may want to seriously consider better bottom end components, or start cruising in the 3s like the rest of the boating world
just saying
just saying
#117
Tim,
just saying
just saying
#119
Great attitude for sure.
drives me crazy seeing people putt putting around in their go-fasts that have serious power.
Back in the day if we weren't in a slow no wake zone it was beat it as hard as you can.
Before getting back into boats again when i was a teenager I had a 440 69 Roadrunner .. My buddies who had Hot Camaros and . Mustangs etc used to bust my balls about my car being apart half the time. My reply was if you used half the power that you built into your motors half the time that i do your chit would break every once in a while too.God I beat on that car nothing like a fearless 17 year old with a built 440 4 speed.
