Season over....tossed a rod... >
Old 08-24-2014 | 07:00 PM
  #141
Full Force's Avatar
[ATTACH=CONFIG]528270[/ATTACH][ATTACH=CONFIG]528271[/ATTACH][ATTACH=CONFIG]528272[/ATTACH][ATTACH=CONFIG]528273[/ATTACH][ATTACH=CONFIG]528274[/ATTACH][ATTACH=CONFIG]528275[/ATTACH]
Attached Thumbnails Season over....tossed a rod...-image.jpg   Season over....tossed a rod...-image.jpg   Season over....tossed a rod...-image.jpg
Full Force is offline
Old 08-24-2014 | 07:02 PM
  #142
Full Force's Avatar
Number 3 and 4 bearing spun, all others and mains so far look good I don't think it was starving for oil, unless those cylinders known for it but I never read that, I am leaning towards bolt or machining issue maybe? Not sure gonna tear down I hope the rest tomorrow...
Old 08-25-2014 | 02:43 PM
  #143
You gonna fix that POS or just keep typing on the computer?
J/K, I drove by Friday after the gym, but I didn't stop cause you weren't outside. I'll call next time.
frickstyle is offline
Old 08-25-2014 | 02:55 PM
  #144
donzi matt's Avatar
What crankshaft was in this? Looking at the edge wear in picture 4 I wonder if an H bearing should have been used and a P bearing was used. Hard to tell from the pictures but I see a couple of bearings with heavy edge wear by the chamfer.
donzi matt is offline
Old 08-25-2014 | 04:45 PM
  #145
Full Force's Avatar
Yaaaa lol, engines in garage now, gotta organize and start making progress haha
Old 08-25-2014 | 04:46 PM
  #146
Full Force's Avatar
PBM Forged crank, same as rods, gonna see what bearing in it tonight...
Old 08-25-2014 | 04:52 PM
  #147
+1 that rod bearing looks like one side of it is chauffeured like the crank made it into a h style bearing..and yes i agree,,all h-beam rods i have used have the h-style bearing in them..
FIXX is offline
Old 08-25-2014 | 05:20 PM
  #148
SB
YUp, looks like PBM uses the H series in their short block BBC kits with forged crank.
http://www.pbm-erson.com/store.php?catId=806&parent=801
SB is offline
Old 08-25-2014 | 05:39 PM
  #149
donzi matt's Avatar
If they are P bearings then assembly error is clearly to blame. I can't imagine the motor even turned easily with a socket and rod side clearance would have been next to nothing, but I will bet it was never checked. It will be interesting to see if you have the same results on the other motor.
Old 08-25-2014 | 05:52 PM
  #150
Full Force's Avatar
Bearing stamped FM assume federal mogul, I will get more pics up later who knows the guy that built these was dumb, I will be using Clevite and probably coated like I normally do, I like the coated ones in case oil gets contaminated it helpskeep alive...
