Season over....tossed a rod... >
Old 09-29-2014 | 04:35 PM
  #241
Full Force's Avatar
[ATTACH=CONFIG]530089[/ATTACH]
Full Force is offline
Old 09-29-2014 | 04:39 PM
  #242
Full Force's Avatar
So many things bad and this was the GOOD ONE!
[ATTACH=CONFIG]530090[/ATTACH][ATTACH=CONFIG]530091[/ATTACH][ATTACH=CONFIG]530092[/ATTACH][ATTACH=CONFIG]530093[/ATTACH][ATTACH=CONFIG]530094[/ATTACH][ATTACH=CONFIG]530095[/ATTACH][ATTACH=CONFIG]530096[/ATTACH]
Attached Thumbnails Season over....tossed a rod...-image.jpg   Season over....tossed a rod...-image.jpg   Season over....tossed a rod...-image.jpg
Old 09-29-2014 | 04:53 PM
  #243
Did it have any oil pressure?
30ftpanther is offline
Old 09-29-2014 | 05:23 PM
  #244
Full Force's Avatar
Yes 70 psi warm under throttle 30-40 idle when the engines were in the diner boat they only had 55 under throttle, and 11lb bypasses, if I didn't add pressure and 30 lb bypasses I would have smoked them instantly...
Old 09-29-2014 | 05:27 PM
  #245
Full Force's Avatar
These were built by the biggest hack I ever seen, if I had been the guy that paid for them and found this I would be in jail!
Old 09-29-2014 | 05:30 PM
  #246
SB
Originally Posted by Cole2534
So what all constitutes a good rigging job? Is there a thread on this somewhere? I need to learn.
Addressing:
Fuel flow
Oil flow and cooling
water flow (volume and psi if non stock Merc)
Electrical - yes. electrical. Wanna know how many Cannon plugs, grounds (watch that new paint !), and variety electrical gremlins get created when replacing/rebuilding a motor.
As far as to read up on all this - there is much here but not at all organized. Best way to find them first is by finding motor broken or tuning problem threads. A lot of answers/questions given/asked by fellow members will be rigging related.
#1 thing to do - if you have a question, ask it ! No one will schit on you for asking. You will be schit on for not listening to advice and for not having some diagnostics of the problem at hand.
Like the famous: "My boat just died. What is it ?" kind of thread. Some things need to be chacked and some symptoms leading up to this, if any, should be shared with the question.
Overall, if you show you care, others will care with you.
SB is online now
Old 09-29-2014 | 05:42 PM
  #247
That thing is a mess!!!!!!
Old 09-29-2014 | 05:48 PM
  #248
Full Force's Avatar
Yaaaa unreal!!
Old 09-29-2014 | 06:24 PM
  #249
What does the crank journal look like?
  #250
Do my eyes deceive me, or does it look like someone took an angle grinder to the crank?
Quick2500 is offline
