Season over....tossed a rod... >
Old 09-30-2014 | 10:23 AM
  #271
Or you spit a main bearing out after a couple pulls on the dyno, thanks Federal Mogul!
frickstyle is offline
Old 09-30-2014 | 12:09 PM
  #272
Nice post, you are a good dude
Originally Posted by SB
Addressing:
Fuel flow
Oil flow and cooling
water flow (volume and psi if non stock Merc)
Electrical - yes. electrical. Wanna know how many Cannon plugs, grounds (watch that new paint !), and variety electrical gremlins get created when replacing/rebuilding a motor.
As far as to read up on all this - there is much here but not at all organized. Best way to find them first is by finding motor broken or tuning problem threads. A lot of answers/questions given/asked by fellow members will be rigging related.
#1 thing to do - if you have a question, ask it ! No one will schit on you for asking. You will be schit on for not listening to advice and for not having some diagnostics of the problem at hand.
Like the famous: "My boat just died. What is it ?" kind of thread. Some things need to be chacked and some symptoms leading up to this, if any, should be shared with the question.
Overall, if you show you care, others will care with you.
stimleck is offline
Old 09-30-2014 | 12:11 PM
  #273
Hmm scary, I checked every one of those boxes with my retrofit, lots of pain to come I assume
Originally Posted by huskyrider
Add to that the first startup before setting timing and no break in oil, etc.
There are many recipes for a disaster.
See ya
Kelly
stimleck is offline
Old 09-30-2014 | 12:37 PM
  #274
Full Force's Avatar
Originally Posted by frickstyle
That was a little rough, maybe I shouldn't have posted that?
Oops, dude I told you howI feel about that, my guy has always had my stuff when I want it every time, he gets my buisness not that it's a Tim but he makes fine for me always
Full Force is offline
Old 09-30-2014 | 12:38 PM
  #275
Full Force's Avatar
Originally Posted by Knot 4 Me
Things go wrong even when you pay people that supposedly do this for a living. Buddy had new NA 489's built this spring. One motor would never build oil temp. Builder blamed sticking oil thermostat. Nope. How about no valve or plug in the filter pad bypass. From dyno to about 5 hours of in boat run time one motor had nothing in that hole. Which is nice...
Wow
Old 09-30-2014 | 02:48 PM
  #276
mmb
Not the bearings fault....
mmb is offline
Old 09-30-2014 | 03:15 PM
  #277
Pretty sure the Engineer at FM agreed that they had a bad batch of bearings, which ended up delaminating, so yes it was the bearings fault.
Old 09-30-2014 | 03:45 PM
  #278
Full Force's Avatar
That sucks is that what happened? Last we takes you were not into talking about it
Old 09-30-2014 | 03:47 PM
  #279
mmb
Hopefully we are not talking about your new engines... If the same builder builds them, I will bet money they will fail again soon
mmb is offline
Old 09-30-2014 | 04:17 PM
  #280
Soo... Are we saying the bearings are bad or the engine build is bad???
30ftpanther is offline
