Season over....tossed a rod... >
Old 08-18-2014 | 05:27 PM
  #51
Full Force's Avatar
I get all that, I guess my question is are the PBM rods ok for my application? they don't look like Chitty rods, I mean they are upgrade to something no? they look as good as Scat, Eagle and such, going to see my machinist tonight to see what he says.... open late on Mondays...
Originally Posted by FIXX
its all in the forging process,,you can take a piece of steel and compress it 10 times to make it strong (eagle,scat,ohio,procomp)..then you can take the same steel and compress it 100 times to smash steel tighter to make them stronger (crower,lunati,) which is why some cranks are more expensive.. then their are cranks like winberg and bryant which go to another level to make them look like a show piece and rods like oliver which are also strong as hell compared to the cheaper eagle and scat..
Full Force is offline
Old 08-18-2014 | 05:29 PM
  #52
Full Force's Avatar
Originally Posted by rmbuilder
Full Force,
The PBM connecting rod is a Scat with either a 8740 or 2000 bolt depending upon how it was optioned.
Bob
so not junk rods I would assume?
I know the rod wasn't my failure itself, but if I have to buy them I want to replace with decent stuff and keep matched if I can (PBM) so both engines are same parts... hate mismatched..
Old 08-18-2014 | 05:58 PM
  #53
Heed your own advice, do it right the first time and don't skimp. You keep asking if the pbm rods are ok, this says you doubt them. If this was Duramax posting the same question about the rods after gernading a motor what you tell him?? There's your answer.
You know damn well that if you use those rods (whether they are good or not) There is going to be that voice of doubt in the back of your head and that cringe in your stomach everytime you grab a handfull of throttle.
Thats not how you want to roll. Your like me and you like to push it and run it hard. To do that you have to have complete trust and faith in your equipment.
phragle is offline
Old 08-18-2014 | 06:06 PM
  #54
MER Performance's Avatar
Default Forging connecting rods
Embeded video incorrectly
MER Performance is offline
Old 08-18-2014 | 06:10 PM
  #55
Agee
But I think what he is looking for more than anything is that for his quality of build and budget what do the expert builders think of these rods for his use, that's all. I am sure he would like to own the best but not everyone can afford it.;
From what I have read he doesn't go out for a day cruise , If the throttles aren't pinned there's no Grin.
Sounds like he got some hard hours out of a previous doubtful build he didn't have anything to do with so maybe if it is speced and put together right this time it will live a little longer.
tommymonza is offline
Old 08-18-2014 | 06:11 PM
  #56
http://youtu.be/xj68mhAA6ss
Old 08-18-2014 | 06:21 PM
  #57
Cool video MER . What is that drum roller doing at the beginning of the vid?
Old 08-18-2014 | 06:31 PM
  #58
It looks; like it's shaping the material for sizing into the die.
Heres a video for those smaller HP packages; http://youtu.be/_T6iqpodKr0
Old 08-18-2014 | 06:39 PM
  #59
vintage chromoly's Avatar
I'm sure you guys will address this but, I'd concentrate on a good oiling system. IE.... Good 10qt. Pan, blueprint the pump and properly set up the pickup to pan clearance and tig it in place, crank scraper, blueprint all the clearances, etc........
I'd bet the house you had an oiling failure an things went south from there.
vintage chromoly is offline
Old 08-18-2014 | 06:41 PM
  #60
That is what I kinda thought too after watching the vid a few times.
But also I figured it is taking 6 guys about 2 minutes to run a rod from start to end. So at 7 dollars a day per a chinese man working 14 hour days and you do the math it works out to roughly 10 cents worth of additional labor to build a forged rod over a cast.
Yea I will take the 2 sets of Forged Rods for an extra 80 cents over the cast ty
