Best spark plugs for the 575SCi?
#31
that explanes why your blowers sound a little dufferent as far as the rpm sound. Sounds like your motors are turning tons of rpms. But uts just your blowers spinning faster.
#33
Engines spin at 5800+, so it's not just the blowers. Are you just trying to get under my skin?
#34
It's safe to say that? Says who? A hot plug is also a great way to burn a hole in the top of a piston of a supercharged engine that already makes higher egts than n/a. Maybe you should stick to sanding bottoms, rather than telling people that a plug 4 heat ranges hotter is safer. Unburied fuel should be handled with proper fuel air management, not with a plug hotter than then surface of the sun.
#35
No i am not trying to get under your skn. My boat spins 5800 too but the rpm of the blower is different cause i have 3.5s. Just sounds different. My pistons look like brand new after 142 hours w yr5s. Stock 575 engines w intercoolers and msds
#36
You can take any motor from any car and go 1 heat range higher and it wont hurt it. In the old days we did it to help the engine use less oil. Yea thats right . One heat range hotter actually cuts down on burning oil in some cases. I tried a set R5673 8s in one hour of use it fouled plugs. I guess my electronics and stuff are flowed for lots of fuel . My motors are stock though
#37
Port and Star engines were getting to 5-7 gallons off on fill ups so I sent the injectors in. One would go max flow as soon as he started raising the pulse width. Another one dribbled a bit at idle, dirty, the rest were a little low on flow, dirty. Four years later, same thing. He said the Merc/Chev injectors are crazy expensive so he got some from a Volvo? Something like that. There's a slightly different ohm/impedance?, can't remember, but when run side by side with the other injectors they flow the same.
Other than the consumption discrepancy I didn't notice anything running.
The engines are slightly fat at idle but no soot build up, just a stumble off idle, be it 5 minute idle or an hour, trying to get on plane that clears up before I'm on plane. Then, to clean the plugs, I hammer the limiters. Mercs system kills fuel so it works great!
Haha kidding, stupid limiter design.
#38
#40
But back to this discusion. Merc 575s sci's will live for years with Hotter plugs. Is a 250 blower really that much more than a na motor. Only the heat when you crank them up. A 250 is a supercharger but a pretty weak one. Now if i put a 671 on it. That would be serious blower. But i heard they dont make as much heat.
