A question about TWINS
Old 10-02-2014 | 09:16 PM
+1 for 1 mile/gallon. If you hammer down a lot, you'll get a little less, and if you're easy on the sticks, you'll get a little better. Twins are worth it though!
chris21hope is offline
Old 10-02-2014 | 10:48 PM
i am getting about 1.4 mpg with my 330l with 454 mags.. I dont fill her up, I just keep a 1/4 fuel and add what I think I will burn based on a couple trips.. Ends up at or just above 1/2.
nailit is offline
Old 10-02-2014 | 11:05 PM
DirtyMoney's Avatar
I was hoping for a different thread when I saw the title!
DirtyMoney is offline
Old 10-02-2014 | 11:17 PM
glassdave's Avatar
Neno the mind boggler
I've tracked nearly all the boats I've had religously on gps. Fill up, reset trip, track miles. These were tracked over entire seasons. I don't lay on the sticks but I do like to run 'em so these numbers reflect a nice broad range of operation. some recent examples
260 Chris Scorp w/twin mild 350's - 1.4 mpg
34 Scarab III w/ stock 454 mags - 1.3 mpg
38 Donzi ZX w/525 SC's - 1.12 mpg
moral of the story figure 1 mpg with a little reserve
08 OPA High Points Champion
glassdave is offline
Old 10-03-2014 | 12:27 AM
My twin 502mpi's in my 32 AT get better mileage than my single 525SC did in my 28 Pantera.
502mpi's burn about 34gph at WOT. At 3500rpms, they burn about half that.
MPG will be determined by boat weight and hull efficiency.
Griff is offline
Old 10-03-2014 | 04:57 AM
Craney's Avatar
Originally Posted by 33outlawsst
Remember that's asking price, its the end of the year and they don't want to set on it all winter, if its what they say it is it wont last.
And TWINS in the Midwest are awesome to
If you and your wife are going to spend weekends on the boat, and if she has a turd cutter the size of this one
, go with the biggest boat you can.
Craney is offline
Old 10-03-2014 | 07:57 AM
Firing up 2 big blocks at the ramp never seems to get old . That boat is prob going to be the infamous vst set up of 96-97 502's see if the vapor tanks and raw water pumps have been serviced
airjunky is offline
Old 10-03-2014 | 08:25 AM
Quinlan's Avatar
You will use ALOT of gas the first yr or 2 after that not so bad. Plus- you always have 1 to get home on
Quinlan is offline
Old 10-03-2014 | 08:46 AM
Ditto
88242LS is offline
Old 10-03-2014 | 08:49 AM
onesickpantera's Avatar
Originally Posted by 2SaltyDogs
OK so this is probably a very cut and dry question but, How much fuel do TWINS (502MAG) actually burn? Now this could be perceived as running wide open and that would be not too long, maybe a day. Basically in a nutshell, I found a smoking deal that is too hard to pass up on a '97 Baja 29 Outlaw with TWINS and low hours from the original owner. The main thing that scares me is the 146 gallon fuel tank and having to fill that sucker up. My boating consists of a few hours of cruising around, a few WOT bursts and the rest of the time, anchored and tied up with friends. This would be my first performance boat and do not want to bite off more than I can chew. I was originally looking at the 25-27' range with a single until I found this Outlaw at a smoking deal ($35k with 240hours in excellent condition). What are your thoughts?
Depends on how much actual boating you actually do. I have friends that burn 4 gallons a day because they are on plane for about a minute then the boat is anchored all day. Then the 1 minute trip back. LOL
As stated, the 502 EFI burns about 33-35 gph at wide open. They will burn about 18-20 at 3500 rpm. If the boat does 50 mph at 3500 rpm, you are getting 1.25 mpg. So, you could go 50 miles at a 3500 cruise and burn 40 gallons. The amount of WFO blasts will increase the fuel consumption.
onesickpantera is offline
