Coast Guard Documentation
FYI. Most states are requiring you to also register your boat in your state even if it is documented. They just want more of your money. Also documentation used to be a way around purchase taxes. Now they are closing that loop hole as well.
A vessel must be a minimum of 10,000 lbs to document. Documenting is a security measure for financial institutions and some require it for financing. It is also security for an owner in any theft etc situation because then it has federal protection and that extend internationally too.
The initialization process is when a vessel is first documented and that takes longer but it does not hinder operation of the boat. The paperwork takes time and my documentation only came to me in Dec of this year and I filed back in April or May. I had a letter of verification that was considered good until the final document came and the letter was considered valid for vessel operation.
If you are under 10,000 lbs then the boat would not qualify. If you are at that then it is another layer of protection for yourself, for a sale and in a state that is not a title state.
Yes you can just reg and be done if there are no requirements on you.
my boat is documented .now also has a reg with bow numbers ..its cool not to have numbers on the bow but not worth the hassel when they pull you over to check if you are legal ..they never know if you documented or not ..plus if you have had a few beers.. not worth it to me to have no numbers
Net tonnage is a measure of a vessel's volume. It should not be confused with the vessel's weight, which may also be expressed in tons. Most vessels more than 25 feet in length will measure five net tons or more. For information about how tonnage is determined, including a web-based interactive form that calculates tonnages, visit the U.S. Coast Guard Marine website. It is straight forward. A 25 outlaw can be documented!
NOT TRUE. NET TONNAGE IS NOT THE SAME AS WEIGHT!!!!!!!
