Need Drive Help
Old 09-09-2002 | 07:39 PM
Madcow's Avatar
Question Need Drive Help
I might have a problem with one of my drives. When I put it in gear one shifter dosn't go as far forward as the other two, and it's hard to pull out of gear. Any ideas anyone?
Madcow is offline
Old 09-10-2002 | 12:25 AM
I would check the shifter cables first. Sounds like it could be binding.
Griff is offline
Old 09-10-2002 | 05:44 AM
DOCTOR DAVE
could be upper gear set, where the clutch cone is at. you would have to drain the oil out of drive, look for any brass or metal shavings, if you see some, pull the rear cover off and look inside you will see a brass ring thats supposed to be pressed on both gears, if one of them has come unseated, thats your problem, and the gear set will have to be replaced. i've done plenty of them, so if i can be of any help give me a call 616-208-4424.
dave
Old 09-10-2002 | 10:01 AM
Gordo's Avatar
Charter Member #94
Default 2 bravos with one stone
I was having the same problem with one of my drives. Checked the cables, (yes, both of them),removed the rear cover but didn't see anything major jump out and grab me.
After reading Dr. Dave's post, I think I'll go back and look again.
Abby-someone
Gordo is offline
Old 09-10-2002 | 11:26 AM
Madcow's Avatar
About what does thyat cost Dave?
Madcow is offline
Full Force
Drives and Lower Units
3
10-15-2007 07:29 AM
Canada Jeff
10
07-19-2007 02:38 PM
thayes11
0
10-02-2005 12:36 PM
Velocity Tom
07-16-2003 10:13 AM
panteraracin
3
02-07-2002 10:36 PM
