Building a Sleeper
Old 02-25-2016 | 06:39 PM
  #71
KCHOTBOAT's Avatar
Charter Member #737
Originally Posted by Papasmurf
We want to spend a week at Lake of Ozarks one summer. Seems like that place is Formula heaven!
You will love the Ozarks. Lots of performance boats. Shootout weekend is great.
KCHOTBOAT is offline
Old 02-25-2016 | 07:12 PM
  #72
Not 100% sure, but I think Mark is setting up engine to max out around 5600 Sent him a text, so will let you know for sure. I know Bblades has a demo program, and I have a business UPS account, so I may demo a 28 and a 30 and see what works best
Thanks for your interest and help. We want to spend a week at Lake of Ozarks one summer. Seems like that place is Formula heaven!
You're welcome! I love projects like this. Post some pics as things move forward.
If the engine combination is set up to turn up to 5600 rpm for max power, you may want to start with a 26P. That puts it at 77 mph at 16% slip, which is realistic slip on a heavy, non-step V hull.
5600 rpm turning a 28P is 83 mph and a 30P is 89 mph. Both of which would be pretty optimistic.
4mulafastech is offline
Old 02-25-2016 | 08:15 PM
  #73
This thread has my attention. Keep up the good work!
distantthunder is offline
Old 02-26-2016 | 09:15 AM
  #74
That's probably too much pitch. What maximum rpm are you planning to turn with the new engine?
BAM has a speed calculator http://www.go-fast.com/boat_speed_predictions.htm and prop slip calculator http://www.go-fast.com/Prop_Slip_Calculator.htm.
Running your numbers and assuming 5500 lbs loaded, 650 HP at the prop shaft and a 225 constant, it comes to 77 mph. Assuming you turn 5200 rpm and have 16% slip, a 28P prop puts you at 77 mph.
Just found out Mark is setting up the engine at 5900 RPMs WOT
Papasmurf is offline
Old 02-26-2016 | 09:19 AM
  #75
Thanks, thats good to know..........and know matter what prop or RPM, my wife's WOT tops out around the mid 70s If I want her with me LOL
Old 02-26-2016 | 09:23 AM
  #76
I dont think I can add pics yet. I cant load a profile pic yet
Old 02-26-2016 | 11:15 AM
  #77
Make sure you have the X dimension handy when talking with BBlades. If the prop is pretty low you would probably be better off with a three blade.
Old 02-26-2016 | 11:17 AM
  #78
Ha! My 292 only tops out at around 70 mph, but in the rough my wife starts to be the limiter...
Old 02-26-2016 | 11:19 AM
  #79
You have to join OSO to post a profile pic and other pics. Or you can use something like photobucket.
Old 02-26-2016 | 01:57 PM
  #80
Originally Posted by ham_r_down01
What prop you running? I'm running a 23 mirage seeing 69/70 mph. Just curious.
Believe it or not it's a 21" Ballistic. It never made sense to me so I had it measured, it measured 22.4" I hit ~53xxrpm. I bought the prop used -- the guy who measured it said it looked like a 23" that was re-hubbed with the wrong markings....who knows. I do know it's the fastest prop I tried.
Oh, and it's an OMC drive with a goofy 1.42 ratio...
BBCLiberator is offline
