Pulling the boat to Florida! Tips for night time >
Old 02-10-2016 | 11:51 AM
What kind of truck
Just pulled a boat back from NC to MO
Had over boost issues in the mountains
Wish I cleaned my turbo before the trip
Donzi Dude is offline
Old 02-10-2016 | 12:59 PM
Leaving Friday night, try to get to the south end of Jersey Turnpike and stop at the Flying J. Won't be crowded, park on the back line.Will get you past D.C. on Saturday. Straight shot from there south.
wideawake is offline
Old 02-10-2016 | 01:23 PM
JS232's Avatar
87 to 88 to 81 to 77 then 95. I've been told to avoid the 95 between Baltimore and Richemond during the week-end because of the traffic. As for the mountains, i'll be pulling a 7000 load (twin axle) behind a 2016 2500hd Duramax.
JS232 is offline
Old 02-10-2016 | 03:36 PM
animalhouse's Avatar
Thats not a bad route. We usually run 95-287-78-81 -66-17-95. But you should be out of the way enough with the route you are taking.
Duramax should be fine with that load, bring plenty of DEF, they tend to suck that **** down under load. I prefer the night driving, but I am wierd like that.
animalhouse is offline
Old 02-10-2016 | 03:44 PM
Quinlan's Avatar
Originally Posted by VortechSS
My .02 - If you've got a 6-lug trailer, bring an extra hub.. and a ratchet strap to tie an axle up in case you don't want to fix it on the side of the road.
First You need to buy a trailer for your tub LOL
Hope all is well Homie
Quinlan is offline
Old 02-10-2016 | 03:52 PM
Watch out for lot lizards at the truck stops and rest areas. They are NOT nice ladies.
Speedracer29 is offline
Old 02-10-2016 | 04:17 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Baltimore to Richmond is manageable, preferably at night. The only other major option is a rather long reroute out to I-81. And the truck traffic through the mountains on 81 is TERRIBLE.
Just call ahead for the hotels, and ask about parking. I've both slept in the boat, and in hotels, and I can tell you I never rest well in the boat.
Arrive late at the hotel, and you should be able to park right in front of the lobby pending the manager.
BUY A LASER TEMP GUN to keep an eye on tire, bearing, and brake temps. Anything that is 10-15% hotter than the rest of the same; is trouble.
This is one of the most valuable towing tools you can own. Check every time you stop for fuel, food, or bio,
It also comes in handy to check road surface temps to see if you have ice risks when towing in prone areas.
Also, take a full set of bearings, as vice grips for ability to pinch off a brake line if you have a brake failure.
Sydwayz is offline
Old 02-10-2016 | 05:23 PM
18v impact with 2 spares and I even carry a extra tire not mounted on the rim, I have had issues finding trailer tires at times. I have heard of people pulling the main fuse to the fuel pump while staying in a hotel
fasthawk6 is offline
Old 02-10-2016 | 05:57 PM
glassdave's Avatar
Neno the mind boggler
Originally Posted by iliveonanisland
Stay at hotels adjacent to tittie bars . . . . . and dont eat the clams at hojo's
Or at the titty bars for that matter
08 OPA High Points Champion
glassdave is offline
Old 02-10-2016 | 06:08 PM
Ing's Avatar
Ing
Veteran: Marine Corp
I assume your are coming down I-87 south from Montreal and then pickup I-95 in northern NJ. I've towed boats many times through this corridor. As one of the other writers pointed out, once south of Richmond it's smooth sailing. I might hold short your first day at Newburgh, NY and use the time to visit OCC or something. Then hit the road again after 7pm. You do not want to be on I-95 and pass through northern Jersey, Philly, Baltimore and DC during any type of commuting traffic. Another option is to depart Newburgh about 9am and you may be able to pass DC just before the evening commute and then hold up before Richmond (although Richmond is no where the traffic as the other cities). Truck stops are the best places to hold up with ample parking and amenities.There is the I-81 option and you could jump on to I-80 West in northern NJ and cut through the Delaware Water gap. It will cost you about two extra hours to get to 81 but you won't have to deal at all with the congested cities. The only thing is you have to be leery of the weather along 81. Snow, ice and fog are problems on I-81 in northern PA. Good luck.
Ing is offline
