Char lynn helm ID, cant find info. >
Old 05-22-2016 | 03:25 PM
Originally Posted by vintage chromoly
You can index the helm in any direction. It's pressure fed.
Thank you
JMPH is offline
Old 05-23-2016 | 11:42 AM
Im still not finding anything, its like the part number doesnt exist.
phragle is offline
Old 05-23-2016 | 12:23 PM
http://www.baileyhydraulics.com/pdf/06-317%20(1).pdf
96scarab is offline
Old 05-23-2016 | 12:32 PM
Its not in there either......
phragle is offline
Old 05-23-2016 | 04:11 PM
direct from eaton/char lynn They are unable to find any record of that part number.......
phragle is offline
Old 05-23-2016 | 04:51 PM
If its a gear driven positive displacement pump you can open it and count teeth, then you will know for sure exactly what you have, or at the very least they can tell you what you have. At least I would think.
buck35 is offline
Old 05-23-2016 | 05:20 PM
It doesnt even match what is listed as the C dimension to figure out displacement, but ut come close to what should be 95 cc. Taalked to Imco today and gave them my ram part numbers and they said I should be around 3 turns lock to lock so I am just goint to put it together and see what happens.. worse would be swapping helms which would be a direct swap out.
phragle is offline
Old 05-24-2016 | 07:22 PM
Can you blow through the press port?
Jeff
hallj is offline
