Water leak advice needed. video and pictures included >
Old 07-27-2016 | 05:01 PM
Default Water leak advice needed. video and pictures included
I just bought this boat 2 weekends ago. had it out to see how she ran on Saturday ran great. noticed that the bilge pump would come on roughly every few minutes. after some further inspection noticed this while sitting still. Not the news I wanted after just spending money to buy the boat.
RGPIII is offline
Old 07-27-2016 | 05:08 PM
Bellows?
jrdonnellyjr is offline
Old 07-27-2016 | 05:10 PM
if thats all it is i will honestly be quite happy. but it doesn't seem to be coming from the normal bellows spot. it is well below the driveshaft and on the opposite side of the shift bellow.
RGPIII is offline
Old 07-27-2016 | 05:25 PM
It definitely looks like your transom is soft and lost the clamping force of the inner/outer transom assemblies. Just went through this with my boat. Only other things that low are the lower trim hoses and exhaust block off plate. Hope it's one of those causing it and not the first I mentioned.
90nova is offline
Old 07-27-2016 | 05:32 PM
damn that's what i'm fearing the most honestly. I've only had it out once since buying it, really don't want to tear it apart and spend what looks like at least $6000 to repair that.
RGPIII is offline
Old 07-27-2016 | 06:16 PM
If it's that soft to be leaking like that you should be able to grab the drive while the boat is on the trailer and see the glass on the outer transom flex when you pull up hard on the drive.
indysupra is offline
Old 07-27-2016 | 06:23 PM
that's whats odd it doesn't move. i have tried moving them up and down and side to side by hand no play at all. i will be there again tomorrow to put some more pressure on it and watch to see if it moves.
RGPIII is offline
Old 07-27-2016 | 06:35 PM
Mine didn't move either, the rot was concentrated in the lower corner by lower mounting bolt. It was a saltwater bolt and had corrosion on the transom assembly that couldn't be seen until I removed it. Ran it 2 seasons like that so I'm sure you can get through this season if you keep an eye on it.
90nova is offline
Old 07-27-2016 | 06:38 PM
id much rather not be running the boat with this leak. if i can get it to stop leaking by tightening the bolts and adding some sealant to the outside of the transom ill run it the rest of the season then pull the drives and engines to have the transom rebuilt.
RGPIII is offline
Old 07-27-2016 | 06:47 PM
Is it a bravo boat. It could be the water pick up tube. They get old and crack
class6 is offline
