Szolack withdrawing from Shootout Action
#31
I hate to see these things happen. I have a 27' cat that I am modifying for top speed.
would a computer controlled wing on the front between the sponsons stop a blowover? You could use a high speed hydraulic system controlled by a computer to control the wing and would engage after the boat reached a certain angle to the direction of travel using a gyroscope as a reference angle.
I watched the video it looked like a clean ejection. If they didn't hit anything inside the boat is it just the impact with the water that does all of the injury? With an open cockpit boat would wearing a large padded life jacket, helmet with neck support have stopped most of the internal injuries?
#33
I'm not getting out of the sport I love. I just won't go 220. I will keep my pleasure boats in the 150 range. I'm Very comfortable running there
#34
RIP and thoughts are with the families.
#35
i don't think it would be that hard for a good programmer. And I don't think the computer would have to be very expensive. Using a gyro and then with parameters set to engage at a certain up angle and be proportional. So the wing would only make a large correction if it was needed. I think I would rather ride through a stuff rather than a blow over. I think the most expensive part of the system would be the high speed actuator for the wing. I just think that if I could afford a 200+ MPH boat with $100K engines - what would be another $25K
#36
Am I dreaming or was there not some fancy aerodynamics on he hydro model from the Gentry container thread last fall /winter? Really skater can't afford to be recognized as a customer eliminator so this should be at the top of their engineering priority.
#38
I talked to Pete today and he is already coming up with a solution In the form of a parachute that will deploy when the Bow reaches a certain angle so the boat will not be able to take flight
#39
As a good friend I have seen you make tough and sound decisions. This one goes to the top of the list.
I am glad we will boating together for joy and not for a plastic trophy that quite literally gets a new owner every year.
#40
On a side not this thread has produced notes from people that prove I am not the only person that has bought a boat and decided I wanted it to go slower rather than faster.
Running together in the low 100s will be every bit the fun of the high 100s if we are doing it together.
