Timmy vs Philly 2017 POUND FEST >
View Poll Results: Winner Pole
Timmy
9.47%
Philly
21.05%
Kevin
1.05%
Tony
3.16%
Donald Trump
72.63%
Multiple Choice Poll. Voters: 95. You may not vote on this poll
Old 05-31-2017 | 04:53 PM
  #741
glassdave's Avatar
Neno the mind boggler
Originally Posted by bck
I'd love for you to take a ride in mine sometime so we could see exactly what difference weight and cog make on the same hull design. ( unless you've already been on one like mine and already know the answer)
I'm in! . . . one of these days our paths will cross out there. No i have not been in an LS Scarab but i tell ya what i have tried my damnedest to figure out a way to stagger mine
08 OPA High Points Champion
glassdave is offline
Old 05-31-2017 | 05:13 PM
  #742
Originally Posted by MILD THUNDER
i cant like this enough
Crude Intentions is offline
Old 05-31-2017 | 05:45 PM
  #743
Originally Posted by I.C.U.Lookin
i cant like this at all anymore. The button is gone!
Fixed it for you.
Speedracer29 is offline
Old 05-31-2017 | 05:49 PM
  #744
Hahaha
Old 05-31-2017 | 05:57 PM
  #745
Full Force's Avatar
Originally Posted by jriggs
Just depends on where you launch your boat. PIB is more like 12 miles from Mazurik. But that is what makes this area so great, you can boat as little or as much as you want. Can run over to Cleveland and hit the flats, or up to Detroit, Toledo, Port Clinton, Huron, Sandusky, etc.....Plenty to see and do.
right... 12 to PIB, 5 to KI from Mazuriks.. Sandusky (Venetion) is 10 miles to KI, 10 ish to Huron, 20 to Vermillion, common runs we do for lunches or hanging out, Canada is 30 miles across from Mazurik, I will do that now that I have a passport... Cleveland is approx. 58 from Sandusky... I went back and forth from Sandusky to KI 2 times last weekend, once from Sandusly to Marblehead (Bidden beach bar) then to Catawba and back to Sandusky... with all the other running around I did about 100 miles... was a great weekend, you guys think I sit at KI all weekend from mazuriks that's just not true, but that's what people on oso think... I love to use the boat, there was a couple years I did less running around like when gas was 5.70 a gallon... But I assure I was not the only one boating much less, I went just as much in my 245 Limited also... every weekend no matter the waves there was a few trips I regret taking as I busted strakes twice in that boat...
it's a great area with TONS of places to go and do stuff, and see...
Full Force is offline
Old 05-31-2017 | 05:58 PM
  #746
bck's Avatar
bck
Charter Member#568
Originally Posted by AJ POWERPLAY
Dave is referring to a 38 ZX, not the 38 ZR. The 38 ZR Comp boats are bad ass!!
None of the above. I was actually referring to his mention of the Scarab. He saw it and replied.
Straight bottoms and flat decks
bck is offline
Old 05-31-2017 | 06:00 PM
  #747
Full Force's Avatar
This happened in less then 5 minutes... from 1ft or less....
Old 05-31-2017 | 06:21 PM
  #748
SB
Good film.
Your boat (on the right with a cover on it...right ??) seems to be moving the least.
SB is offline
Old 05-31-2017 | 06:25 PM
  #749
Full Force's Avatar
Right, could not pay me enough to dock on that outside wall... for obvious reasons...
Old 05-31-2017 | 06:45 PM
  #750
Default Yes
If Tim was on this lake it would be the roughest lake in the nation?
ICDEDPPL is offline
