450r/500r
Old 01-17-2017 | 08:48 PM
Ya we will see. I'm more interested in seeing the NA DOHC motor that will make around 850-900. My guess is 2 year warranty and 500 hours before rebuild. It will do to the I/O market what the 400 has done.
PS- Dale those 500s on your boat will just be flat out awesome!
precisiondetails is offline
Old 01-17-2017 | 08:54 PM
It would be nice to see some of those 500's show up on performance V hulls. Twins on a 30ish boat would be a hard runner.
Wildman_grafix is offline
Old 01-17-2017 | 09:32 PM
https://youtu.be/PM80wUW6oxY
3 liter
V8
Naturally aspirated
4 stroke
200 lbs wt base wt
400+++ hp
skate is offline
Old 01-17-2017 | 10:54 PM
I wish the HP increase were real as well as available before my order is placed. According to the CNC verado prop guy at Mercury racing, it only a rumor. It only logical that they evolve this platform to higher levels since they are selling so many.
You can't just increase the boost by changing a pulley like someone said in this thread. The boost in controlled by the ECU and the SC is setup to run at full capacity and then boost limited in software. This ensures a constant 400 hp to the prop under most all conditions. The boost can be raised through an aftermarket tune already offered, but the design limits the increase to only 25hp. Going higher requires a larger whipple SC as well as other changes from Mercury.
bultmand is offline
Old 01-18-2017 | 02:59 AM
Dean Ferry's Avatar
Veteran: Air Force
Fake news !
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 01-18-2017 | 06:45 AM
2jz
Originally Posted by Dean Ferry
Fake news !
Im sure alot of these inboard lovers would be happy to hear that because they cant stand for an outboard boat running pass them.
2jz is offline
Old 01-18-2017 | 08:26 AM
Dean Ferry's Avatar
Veteran: Air Force
Actually, I was just commenting on the fact that there will NOT be a Merc 500 Hp O/B this year, little birdie told me so , so it's not a slight towards O/Bs, of which, we own 1 now. Our next boat will be either a diesel powered or O/B powered.....
Attached Thumbnails 450r/500r-2007_hydro_stream_d2.jpg
Old 01-18-2017 | 08:53 AM
not so fast Phil keep in mind all this power is pretty linear through shafts (which easily handle the power) in a straight line only making a direction change a single time at the lower and in outdrives like bravos the upper is the weak link, the lowers are pretty durable, if the lowers on these are adapted XR stuff it would fall within range i would think.
Early verado lowers had issues at much lower ratings. I hope you're right though.
hogie roll is offline
Old 01-18-2017 | 09:08 AM
Double R Performance's Avatar
NorTechNorth.com
I hate to throw a wet towel on this campfire. But this is a Photoshop deal. The last time Mercury had a big outboard release was the 400. I got four of them before the show. We have no 450's. We have no 500's. Be prepared to be disappointed at Miami if you actually think this is happening.
Double R Performance is offline
Old 01-18-2017 | 09:12 AM
OL40SVX's Avatar
Correct!
OL40SVX is online now
