Corrosion on lower unit, is it a warning?
#31
If you consider moving forward I can connect you with my surveyor friend (SAMS Certified) if you want to get a survey done prior to the purchase. He is very detailed in his inspection (a little anal) but that is what you want when buying a boat. He lives in the same city as the boat.
Cheers.
#32
I have to agree with Roll with it. I'm from the same area and deal with the same problem. My everyday boat get the corrosion on its outdrive. And all of my grounding is connected as well as a working mercathode. The Mercato deorfler doesn't work that great in a fast current area. As well as it takes a few hours for it to get a good shield around the outdrive. I change my anodes twice a year with the magnesium ones. They are the ones that corrode the fastest in fresh water. But I run a stainless prop and I don't doubt other boats putting off stray current. This is just what happens in this area and I would imagine the area that boat is from. My dad's old boat got cleaned, sanded, and painted every year. It stayed in the water all summer and we drove the hell out of it. He bought it in 1992 and had a 350 mag with an alpha 1. With the correct maintainence and painting it it lasted for 17 years on that boat. Then we junked the boat and kept the motor and drive. It is not in the best shape with the corrosion over the years but every bolt comes out and it still is functioning. I would say if you have stock power and do some cleaning up on it you will be good.
#33
Hey rak rua: I think current photos are mandatory to gauge honesty of broker relative to condition of the entire boat. Everyone has a different opinion as to what is "minor" and what is "mint". The input from uluru is very valuable since he verifies this corrosion as typical for that area. It would be easier if you just moved to North America Bud!
#34
I hope you're going to look at the boat yourself. It seems if that was ignored many other issues were as well.
I'd walk away.
#35
According to a detailed article in BoatUS this month There's much more to correcting (correctable) corrosion than what you suggest as a repair procedure. It is well known that many times a single mercathode system, even when working correctly doesn't provide enough field to stave off corrosion. I've read of members having to run multiple is in tandem. Looks like that was teh case with the outdrive, or not working altogether.
I'd walk away.
I'd walk away.
R.E. This boat, I have had contact with the broker and nothing to report at the moment, if things change, I'll update the thread.
Thanks to all who've posted on here, some great info and a couple of genuine offers of help from guys in the area.
The search continues..........
RR
#36
If this kind of corrosion is typical of a certain geographic location , I would start looking for a crashed UFO under the water somewhere ..
Not much is more corrosive than hot super salty water in SW Florida . And if I saw that on a boat here I would say its a stray electrical problem, not related to water conditions at all.
#37
If it has shorepower and is plugged in, (battery charger) then stray current could be possible, if this boat has grounding issues or the galvanic isolator or mercathode is shot.
I see it more of a dissimilar metals, with the alum being the more noble when its next to SS. Probably have signs of corrosion around all the drive nuts and oil fill plugs too
