Brass raw water pump
Old 04-17-2018 | 02:26 PM
Default Brass raw water pump
I have the raw water pump apart off my 496ho and I have some light scoring inside which seems to be common with them. The scoring isn't very bad but don't want to put a new impeller in and have prime issues with it. Is there still a wear plate kit you can instead of replacing the whole pump?
chartersj is offline
Old 04-17-2018 | 02:35 PM
If you replace get a pump from Hardin Marine.
sbdennis is offline
Old 04-17-2018 | 09:17 PM
The Hardin marine setup is the ideal setup. Howver. I've been running the Aftermarket Marine wearplate/impeller kits since 15' with no problems. If you can catch your fingernail on the wear ridges in the stock housing it needs attention. Just a new impeller will not fix your problem.
Ryan00TJ is offline
Old 04-18-2018 | 05:19 AM
ok sounds good...where did you find your kit? I cannot find the jc marine one I have read about.
Old 04-18-2018 | 07:25 AM
Have had one of these on both my boats without issue since 1995.
https://www.ebay.com/p/OEM-Mercruise...1173657&chn=ps
Changed to the Hardin marine SS last season on the Formula and notice when installing that there is a slight rise in one side of the center edge. Don't know if this is an issue or not, but trying to get my oil temps down. Installed a water pressure gauge this season. Should be able to see what is going on.
Woops my bad, wrong pump
AllDodge is offline
Old 04-18-2018 | 12:00 PM
Captains Choice in Fort Walton Beach, FL normally has them in stock. At least that is where I bought mine. They work great, I've been using them for about 4 years with no problems...
alindquist is offline
Old 04-18-2018 | 12:40 PM
Thanks for the help..i ordered the aftermarket marine kit... Will use it for a couple years then will look into getting the hardin ss pump.
