Sterndrives will not go down..
First things first, try jumping the solenoids.
BIGSLOW is correct.
Green wire is for down (green, grass, down)
Blue wire is for up (blue, sky, up)
It does seem a little odd that both are not working, but it could happen.
Tip: IF you are going to replace a trim solenoid, replace BOTH of them on the pump, up and down. 3 bolts pulls out the 2 solenoids. If one is dead, the other is likely not far behind, and they are cheap my boat parts standards. Keep the spare, used, good one on board in case of emergency or to toss to a friend if needed.
BIGSLOW is correct.
Are you using the "trailer" switches on the dash and have you tried the trim button on the side of the throttle?
I'd assume solenoids as well.
Also check backside of trim switches. Possible the ring terminals popped off the switch, but odd for it to do on both....
You also seem to have problems with starting this boat (other thread). Why not pay a marine or good auto mechanic to come look at it for 2 hours? May save you days of aggravation?....
"Runs and Sounds Great, CLEAN AND CLEAR TITLE, Tested and inspected, Ready for Fun Now, Great Looking Speed Boat, Well Cared For"
if this was in the add of the one you bought on EBAY someone need a talking to. hope you get it sorted out and start to have fun on it
