Sterndrives will not go down.. >
Old 09-21-2018 | 11:47 PM
Click the clicker a hundred times. There is dust in your solenoid between the points. That will knock it out. Why do I know?
wwahl is offline
Old 09-22-2018 | 12:47 AM
Originally Posted by brianracedesert
The trim button on the throttle does the same thing .. Does not go down but goes up ... Same with the dash switches...
Check all your power wire connections on the back of the dash switches.
The throttle switch is wired off the dash switches with a diode to prevent being backfed.
The throttle switch won't work if the dash switches don't work.
Griff is offline
