Need tips on floor dollys
Old 04-27-2020 | 10:45 AM
jeff32's Avatar
Default Need tips on floor dollys
Hey guys! I have those 2 dollys with 4 x 360 degrees spinning 4-5 inches steel wheels each i used to support my project on the floor. I can swing lets say the back of the boat with one arm from side to side no problem. But if i want to move it forward or backward even with 2-4 people it is not moving, needing my fork lift. I have 4 wheels dolly under the 2400 lbs race car and i can move it easily by myself anyway i want! What is the difference? Is it because the wheels are all 360 degrees? Is it because they are too small? If so why am i able to swing side to side easily? Here is a picture for you to see the dollys. What is everyone using in boat shop production or repair facilities?
thanks!
jeff32 is offline
Old 04-27-2020 | 12:49 PM
jeff32's Avatar
they are actually 6 inches casters i measured them at lunch... should'nt be too small right?
jeff32 is offline
Old 04-27-2020 | 01:36 PM
Yardarm - Marine Products & Metal Fabrication Specialists
Jeff,
I have two of the Yardarm economy dollies and they work very well on V bottoms.
floatingphil is offline
Old 04-27-2020 | 02:26 PM
jeff32's Avatar
Thanks for the link!
i am confused looking at these and mines are not much different cant see why they are tough to change direction
thanks again!
jeff32 is offline
Old 04-27-2020 | 04:15 PM
jeff32's Avatar
maybe because my dollies are too long... wheels are too much apart makes it harder to change direction... might have to think about that...
anyone could confirm that?
jeff32 is offline
Old 04-27-2020 | 07:27 PM
jeff32's Avatar
Jeff,
what size boat are you easily moving around?
jeff32 is offline
Old 04-27-2020 | 07:37 PM
jeff32's Avatar
Jeff,
jeff32 is offline
Old 04-27-2020 | 09:31 PM
About 5000 lb and 26 ft long is as big as I've had on them. Without the engine and drive it is easier though.
Old 04-28-2020 | 09:01 AM
First of all...... NICE SHOP JEFF !!
Now for the dollys, I've had a lot of experience moving stuff around my warehouse and tight fits as I do winter storage for cars and boats.
I find that if the wheels are good for side to side but you are having trouble changing directions it is a matter of technique / momentum
If the boat comes to dead stop and then you try to change direction it is almost impossible.
You need to try changing direction before needed, ever so gradually until you are aligned in direction you want to go.
Sometimes it takes a couple of back n forth but it never failed me
kinda like squeezing the 350 in between 2 parked cars and when you get out there's only 3 inches in back and 6 in front and all the bystanders are wondering how the heck you did that
Let me know if you need a hand, we're less than an hour apart
Excess is offline
Old 04-28-2020 | 11:01 AM
jeff32's Avatar
I will then try with more powerful people besides my daughters!
thanks for the offer if i get stuck i will contact you for sure to get a teacher!
jeff32 is offline
