Need some info on this boat from the professionals. >
Old 04-14-2021 | 10:19 AM
  #71
thisistank's Avatar
Originally Posted by boomer
Spoken with the knowledge to back that advise.
thisistank is online now
  #72
resurrected's Avatar
The amount of compost inside, and the staining on the hull makes me believe it has been outside for more than 2 winters. Assume it needs everything.
resurrected is offline
Old 04-14-2021 | 10:22 AM
  #73
That is a nice example for sure! that would be American dollars? so 47635.77?
3D CIG is offline
Old 04-14-2021 | 10:24 AM
  #74
I was under the same impression, but everyone's got a story I guess.
everything is stretched far from the truth..
3D CIG is offline
Old 04-14-2021 | 10:25 AM
  #75
Subscribed. (And hoping the OP comes to his senses, takes the rose colored glasses off and runs as far an fast away as he can.
Alwhite00 is offline
Old 04-14-2021 | 10:30 AM
  #76
I assume by your conversion rate that you're in Canada, plus HST (at least in ON) when you cross the boarder, there has been a couple 28ss on Kijiji off and on for a couple of years.
Old 04-14-2021 | 10:32 AM
  #77
Buying this boat will be a MUCH better decision IMO... Your full restoration on that gremlin will probably be close to $100k... You'll be at 1/3 of the price if you buy this and you won't waste 4 years of your life finishing off that other project.
Gmogomez is offline
Old 04-14-2021 | 10:37 AM
  #78
Yeah I'm on Ontario.
3D CIG is offline
Old 04-14-2021 | 10:50 AM
  #79
Up here, any water that makes it into the wood will cause it to rapidly deteriorate due to the freeze thaw cycles (which can occur many times in one season). Unless you can water test it and inspect it for rot, I personally wouldn't pay anything for it. Even at a zero dollar purchase and do all the labour yourself you will need to have at least $50,000.00 available to restore it. Assuming the engines are ok
I have put almost $60,000.00 in mine after buying it and still have no interior, and I have done all the work except freshen the engines
Old 04-14-2021 | 12:49 PM
  #80
Originally Posted by BDiggity
you talking to me???
Who you kidding??? You're at more like 7 years in
Griff is offline
