Swim platform Installation >
Old 05-07-2021 | 04:38 PM
Default Swim platform Installation
Just removed our top gun swim platform so it could get stripped and powder coated...noticed it was installed using silicone. question for re-installation...
what’s the best sealant/adhesive to use? Was thinking 3M silicon or 4200? Thoughts?
1MOSES1 is offline
Old 05-07-2021 | 09:40 PM
seafordguy's Avatar
I think I used 4200 when I put mine back on after powder coating.....
seafordguy is offline
Old 05-08-2021 | 12:12 AM
I used 4200 when I did the same thing last year.
Griff is offline
Old 05-08-2021 | 06:25 AM
I like 4200. Silicone isn't much of an adhesive.
thirdchildhood is offline
Old 05-08-2021 | 06:27 AM
offshoredrillin's Avatar
4200 as the bonding agent and to surround the holes, no harm in useing clear silicone around the braces after it is tight to stop water and dirt from getting in between the metal and the gel.
offshoredrillin is offline
Old 05-08-2021 | 10:04 AM
thanks guys...4200 it is.
was a little surprised to see cigarette only use 2 thru bolts to attach the platform.
the rest are merely screwed into the wood...kinda strange.
1MOSES1 is offline
Old 05-08-2021 | 10:44 AM
F-2 Speedy's Avatar
put silicone on the screw threads before install, it will help keep out moisture
F-2 Speedy is offline
Old 05-08-2021 | 12:18 PM
may not have had one from cig depending on the year, could have been done by a previous owner. all of them should be through mine is a 2000 and all are through bolted. if you have the ability to do it , you should.
Old 05-08-2021 | 02:41 PM
seafordguy's Avatar
I seem to recall one of my center bolts was a lag, but the others were all thru bolts.......
