Anyone running a hydrofoil on a stepped hull?
#51
Okay, here is thread i was talking aboute. Here on oso, but we didn’t reply there recently:
Where’s my speed at?
hmmmm
hmmmm
#53
Yep as usual, wasting everyone's time.
On here, he has no clue as to his own boat.
Then he gets hostile and we're the idiots.
FWIW, by chance when I was Googling Senza Spectre pics, I came across an Iboat thread by the same guy from 2018 fighting the same issue, here.
Apparently he has no clue or he needs someone that does to get the boat squared away if there is an issue at all.
( I have a stepped hull but it has more than one, so am I allowed to talk?)
#54
Its not a cat, it does not ride on a pocket of air, it rides on aerated water. Go to a poker run or a race and look at the boats, It doesnt mayter if it has one step or an outerlimits with 27 steps, they will all have tabs. That said your boat, steps or no steps is a single correct? singles are susceptible to torque which can cause them to lean. a twin has counter rotating props that counteract the lean. On a single slightly dragging a tab can help considerably. You need to take the time to learn the hydrodynamics of a stepped hull as there are some things about them that can get you in trouble really quick. You are correct in that they handle different than nonstepped hulls but you need to go a step further as to how.
#56
On the back left of the transom, it looks like someone installed a single trim tab and it got removed at one point.
Maybe try a drive with a counter rotating prop like a B3. Will help with torque steer and provide a little more lift.
#57
I think the problem is you have a crappy designed boat and the owner is just as stupid... in boating terms you're whats known as an askhole, you ask questions and keep changing the question till you get an answer you want... so einstein, good luck w your tub, hope you dont kill anyone... let us know if you decide to go to any runs, so we know to look out for the ill handling POS, with the know it all behind the wheel.
#60
