Phenomenon
#31
Speicher,
I read that, as well. This may have been where I read there was only one shakedown run, as it was discovered the props were damaging each other, and they didn't think they'd be able to rectify the issue without major reconstruction of the transom. It seems to me the simplest solution would be to lengthen one prop shaft on each side by just enough to clear the interference. I've seen this done on model boats with twins. This could have also led to the short-of-expectations 195MPH top speed, with a lack of sufficient prop blade area to push enough water to overcome the weight of the boat.
This begs the question, though.... Why hasn't anybody done this with a Mystic. We've seen quad engine cats before. There was and MTI (I think) for sale within the last year with four 1200 blower motors (quadrotors, I believe?). We know there's room to do it.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#32
Moses,
Kinda, sorta.... They are shafted together in tandem, with only one propshaft per side. They start together (per side) and run in mechanical sync. What a beast. But I can definitely see the benefit of having four props pushing water, though.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#33
Speicher,
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#36
2011 Nor Tech 50 Roadster (marinetechnologyinc.com)
This is the one I was remembering.
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#37
#38
Moses,
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
#39
I was recently thinking about Al Copelands Phenomenon and what became of it. To me it is definitely one of the most interesting boats ever built in Offshore Powerboating. I really hope that some day someone with a lot of money completes this unique boat in the Memory of Al Copeland an Offshore Legend.
#40
Speicher,
Thanks. Brad.
(937)545-8991
Thanks. Brad.
(937)545-8991
Because a mystic doesn’t need 4 engines!!! My 50 Mystic with 1850hp turbines ran 210 when it had plenty of room to get there. Qatar ran 244 in kilo with twin T55’s, how fast do you want to go!??!?! Lol
