GPS speedos
Old 02-06-2003 | 11:06 AM
Official OSO boat whore
Dyno-I'm using a Garmin e-map unit. I spoke to Garmin about the availability of a patch cord with both power and output. The guy that I spoke with said that they used to carry them but were having a problem with them. It seems as if people were hooking up straight 12v (like I was going to-DOH!) and were frying the units. To save the consumer from themselves, the only way you can get external power is with a cig lighter attachment.
The tech was nice enough to point me to a company that made the correct patch cable. I don't recall the name, but I can dig out at home-if you guys want it.
BTW-I noticed that Gaffrig and Nordskog came out with the GPS speeds at the exact same time. Coincidence? I suspect there is only one supplier.
Cord is offline
Old 02-06-2003 | 11:12 AM
birdog's Avatar
Very True Wally....
I am just so used to going straight to the factory I didn't think
it through at the time. I won't do it again though.
birdog is offline
Old 02-06-2003 | 11:15 AM
Clay Washington's Avatar
Why would you want a GPS speedo??? I like the readings of my "normal" speedo.
If a passenger wants to know how fast we are going, I just point at the speedo. They don't know that it lies on the high side by about 4 mph!
Clay Washington is offline
Old 02-06-2003 | 11:24 AM
dyno's Avatar
Charter Member #655
4!!!!! **** mines off by at least 10!!!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 02-06-2003 | 12:37 PM
SpectreBoy's Avatar
Default Bayley & Dave M
Bayley, I have a 168 Garmin plus the GPS speedo, the speedo only wiggles when I flip the recall thingy but won't show speed at all, maybe what you said above is my problem, so if ya could say it in english or just so I could understand it, maybe I could get mine to work like it should.
Dave M, my 168 Garmin in the menu section has a option for sm, med, lrg, and x lrg, so I can make my speed really big so it's easy to see, so maybe just check your settings and you might get some bigger numbers.
SpectreBoy is offline
Old 02-06-2003 | 10:38 PM
rbtnt's Avatar
here is how my garmin 12CX gps is wired to my gaffrig analog gps speedo using the data/power cable from gaffrig.
the brown wire from the gps data/power cable is connected to the center wire on the smaller connector on the back of the speedo. this wire is white.
the white wire on the gps data/power cable is not needed for the speedo.
speedo large connector
red +12V
black ground
violet center position of clear/recall switch
gray recall side of switch
orange clear side of switch
speedo small connector
center white lead <--> brown lead from gps power/data cable
gps setup screen interface page
None/NMEA
NMEA 0183 2.0
4800 Baud
rbtnt is offline
tgersx
3
06-09-2007 09:27 AM
tgersx
06-08-2007 05:18 PM
BRUCE SEROFF
06-10-2003 03:15 PM
kook
05-11-2002 10:32 AM
