super cat light - questions >
Old 03-03-2003 | 03:53 PM
timucin's Avatar
Default super cat light - questions
while watching freeze frame , the narrator was saying 500hp engines to most of the boats.is this true?is there a limitation?
so why are they using ssm-6 drives with 500hp engine?
what are the speeds on this class?
thnx for help..
timucin is offline
Old 03-03-2003 | 03:58 PM
mr_velocity's Avatar
yes it is true, hp500 is the only motor. We ran #6 drive because they will never break with 500hp. You have to finish to win.
mr_velocity is offline
Old 03-03-2003 | 04:58 PM
DPT MOTORSPORTS's Avatar
LOOK AT THE LEAD NOW!!!!!
For the 2003 Season SCL can run one of three power options. That being the HP500 EFI, HP525, and the GM Vortec HP3. Also having the choice o Sterndrives such as the Mercruiser Bravo One, XZ, XR, XR Sportmaster, XR Short Sportmaster, and the #6 SSM Sterndrives from Mercury. The IMCO Xtreme Advantage Drives are also approved for this class
DPT MOTORSPORTS is offline
Old 03-03-2003 | 05:41 PM
timucin's Avatar
i know you cant beat a 6 drive but its very expensive.i mean bravo sounds enough to 500 hp. am i wrong?
i am talking about 40k price difference...
timucin is offline
Old 03-03-2003 | 05:52 PM
Your best answer to that would be to someone who has raced the class. I have not. I heard that the #6 did not need the amount$$$$ of maintanence as the bravos. Now the Bravos have been upgraded and built to stronger tolerance I am told. I have also been told that you give up MPH with the #6 but make up for it in the rough water. Team Tellium was a #6 boat and was very dominate with there set up. I think now you will see more people running the bravos cause of the speed advantages with them.
Old 03-03-2003 | 06:07 PM
Reindl Powerboats's Avatar
Like he said, you have to finish to win. Think the DPX is also allowed in SVL, not sure of SCL
Reindl Powerboats is offline
Old 03-03-2003 | 06:12 PM
timucin's Avatar
Chris sorry forgot to call.will call you tomorrow from your office
timucin is offline
Old 03-03-2003 | 08:35 PM
What you say is very true. The #6 drive costs $0 to race, just the inital cost. I also think anyone who is serious about racing, a cat anyway, needs to completely rebuild a bravo after every race and probably replace the gimbal ring and bell housing too. Maybe every two races at the most. There were a few gimbal failures and I haven't seen an upgrade there, yet. The bigger drive shaft help a lot also.
In rough water you can't beat the #6 drive, if flat water you really need to work to be competitive.
I was the driver for Tellium the two years it raced.
Old 03-04-2003 | 06:45 AM
timucin's Avatar
mr-velocity: what are the structures of the teams racing in this class. you said you were the driver.were you also the owner of the boat?what i am wondering is in this class boat owners or more professional people race ?
-can you also estimate a yearly budget for this class including the boat,drives,transportation etc.?
and last question
what is the budget for each race assuming nothing is broken
thnx
timucin is offline
Phantom1
07-07-2003 12:22 PM
1HYPER1
03-19-2003 09:46 PM
1HYPER1
02-28-2003 07:44 AM
BlakeandBrock
02-07-2003 04:26 PM
cgarrett
11-24-2002 02:35 PM
