What prop should i use??
Old 03-19-2003 | 03:38 PM
21 Hustler's Avatar
Default What prop should i use??
Last spring I purchased the 21 foot Hustler with flames on it, the one pictured on the Hustler website. It has a 6.2 L with a Whipple Supercharger on it. Im getting about 500 HP out of it. Im reaching speeds in the low 80's. However the prop just doesnt feel right..im runnin a 27" 3-blade mirage, i have tried a 29" 3-blade mirage and it just seems too much for the boat. Any suggestions on different styles or types of props..any suggestions at all would be great...thanks Justin
21 Hustler is offline
Old 03-19-2003 | 05:01 PM
Rick#29
Take that prop that did work and have it lab finished,it will help big time.
Old 03-19-2003 | 06:58 PM
21 Hustler's Avatar
will the labbed prob help handling, or just top end...also do u recomend any sort of 4 blade or someother kind of prop?
Old 03-19-2003 | 08:17 PM
BAJA WILL's Avatar
Registered User
21 Hustler,
I am guessing here but you may try a 29-31 Hydro, if you are pushing 500hp in a 21 foot boat you should be able to spin it. Should put you into the 90's, need to ask yourself if you want to go that fast in a 21 foot boat, I have been in a 22 Checkmate w/350mag running 65 in 2-3 chop and is really hairy.
Small boat BIG power! Have fun
BAJA WILL is offline
Old 03-19-2003 | 08:20 PM
21 Hustler's Avatar
i have a normal rev limit of around 5000 rpm, this boat is a monster, i think it could handle high 80's, as long as the trim is right it is stable...i run on a lake so it is glass during the week, but really choppy on the weekends...thanks for the suggestion
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
