Shotgun Muffler Tips???
Originally posted by 572Daytona
Thanks for the reply, Waterfoul. So I'm assuming since I have 4" collectors on the Bassetts that I would need the 4" Shotguns then?
Kaama, I had the original ones. They had holes drilled in the flapper plate, not like the new ones with the holes in the bottom of the pipe. They will open fully at wot and dont have any backpressure. I think you can still get those.
Originally posted by KAAMA
From what I have seen over the years, the "over the transom" style of Bassett Headers usually have somewhat of a "flair" or "bell" shape at the very end of the tailpipe. So make sure you've got the correct measurements before you order------Either way I am sure Drew Marine can get you point in the right direction.
Kaama, in full open position, the shot-gun tips are not any quieter. Around the dock, or at idle speeds, the piston is keeping flapper closed and forcing thru holes in bottom of tips. This directs exhaust toward the water. Once, you start opening up the throttles, pressure from exhaust is over-riding piston force which results in flaps opening up. Brings back that sweet sound of a regular thru-hull! Great product, simple & reliable. Also can adjust pressure as to how quick they open-up.
I've got over 100 hr.s on mine and, I too, really like them. Their design is a great example of the KISS, (Keep It Simple Stupid) theory!
MD
MD
Everything is for sale @ a certain $$
I might be interested in a set.. I have talked to Drew about the ones I have now, with holes in the plate, he said they are very old and the new ones are better. I am running a them at the end of my Borla mufflers with dry exhaust all the way out.
So count me in on a good price if possible. Drew also told me that my motor would require a set with more holes in them, so that info would be needed from each customer..
Dick
Dick
