BEWARE of  Power Marine and Blown1500 >
Old 07-22-2003 | 07:15 PM
  #231
dyno's Avatar
Charter Member #655
I need to know!!!!what happened at the lake?????
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 07-22-2003 | 07:21 PM
  #232
G-Force's Avatar
Why do I either see him floating in the middle of a lake with a dead engine, or in jail for flipping out when the motor died?
G-Force is offline
Old 07-22-2003 | 07:42 PM
  #233
ragtop409's Avatar
Originally posted by Allan4
I tell ya guys, the more digging around I do, the more I am convinced that Bobby/Jack has done little wrong.....and certainly nothing that would warrant this sort of abuse he is taking. Has he made a mistake or two.....?? Probably, I'm not sure, maybe he has. But not enough to be getting hammered like this....hell, who HASN'T made the same mistakes. I make mistakes everyday....better look in your closets people...
Allan
If you ask me the only people Is see get banned from the board make the BIGGEST mistake of all $$$$$$$$$$$$$ did he make some well helping people save some ?????????????????????? Rag's
ragtop409 is offline
Old 07-22-2003 | 07:45 PM
  #234
VelocityMark's Avatar
Guys I don't know why Mark has not posted a response by now, but I can tell you that he did go to the water and he did go for a ride and he did take the boat home. And from what I am hearing he was happy. Now lets just see if he is a man of his word, because it sounds as if Robert was a man of his.
Mark
VelocityMark is offline
Old 07-22-2003 | 07:52 PM
  #235
PhantomChaos's Avatar
Hopefully out getting ****-faced happy!!!!!!
PhantomChaos is offline
Old 07-22-2003 | 07:57 PM
  #236
dyno's Avatar
Charter Member #655
I hope so!!then maybe I can get back to getting great free advice from all involved!!
dyno is offline
Old 07-22-2003 | 08:30 PM
  #237
CHAOS REIGNS's Avatar
Sorry for the delay guy's!!!
Had a T-storm come through and my cable has been down till now.
details to follow
CHAOS REIGNS is offline
Old 07-22-2003 | 08:32 PM
  #238
Originally posted by formulafastech
MArk's ISP was down. Post will be up soon. Boat is fixed and running fine.
Yeah........SURE!!!!
Attached Thumbnails BEWARE of  Power Marine and Blown1500-cj_14965%5B1%5D.jpg
Old 07-22-2003 | 08:43 PM
  #239
Ok -- met with robert this afternoon -- turned out the problem was a couple bad rocker's. For some reason they were not being oiled properly and they over heated causing the pushrod failure. (I am sure once robert is re-enabled he can give a more accurate description).
Robert put new ones in with a higher grade push rod -- fired it up and seemed to run fine. During this time Jack Bailey had called to find out how things were going. He then offered a set of Gold Crane roller rockers (at no charge to me). This was to ensure that there would be no issue at all with rocker failure ever again. I thank him and TJ(Ambusher) for providing the roller rockers and having that extra security in the motor.
Got them installed and adjusted (robert and his helper did it right there while i waited) and we then headed down to lake wylie. I met up with Ambusher and he went out for a ride to test out the motor. He did take some video and a few pictures (hopefully he will post it).
The only problems found were a leaky pepcock (just wasn't shut all the way) and the alternator belt was slipping. They were able to fix those two items on the spot and every thing ran fine. He did point out i had a leaky exhaust manifold which i already knew about (new ones will be on order shortly - -money money money).
So the bottom line is that power marine took care of me in the end.
Also i'd like to thank everyone on OSO -- I was truly "upset" with this whole ordeal -- and with your encouragement I gave them another shot -- and things worked out well.
I am up to 3 hours on the motor -- and I'll be taking it gently for a while -- but i have my fingers crossed that this phase of my boat project is complete.
Steve can you turn on power marine so they can respond
thanks
Mark Pejsa
Old 07-22-2003 | 08:44 PM
  #240
damn -- that does look like me !!!
although i am much more of a captain morgans kind of guy!!!
