Originally posted by burtandnancy If you want to stay away from the weight, cost and drag of #VI's, take a good look at the various drives from IMCO... T2x |
i d rather have drag then a broken bravo
tryarnesons asd 8's , fiore's have a history with arneson and they are cheaper then 6's
Originally posted by Troutly T2x.....welcome back :) T2x |
We will work with you to build a very reliable package. We have some 750 naturally aspirated engines that have over 400 hrs on them. Jassman's boat is at paint, and will be out in a few weeks. His engines made 745 hp @5400 w/ wet exhaust and mufflers. His engines were designed to be extremely reliable. The EFI systems compensate for most conditions, and have a fail-safe mode, which will add fuel and reduce timing in the event a problem occurs. We will also be working with a few major magazines on projects in 2004, and could probably use your boat as a feature. Give me a call if we can help you in any way.
Thanks, Steve |
Originally posted by cuda Just curious why you don't want Merc? You could be just about anywhere in the world if something went wrong, you could have it covered under warranty. Try that with an independant builder. I am going to call all the builders and se what kind of pricing I am in for then get back to Mike and Paul with what I find out...Tomorrow I plan on calling Pfaff, Sterling, and maybe 1 or 2 more if I have the time. I spoke with Total Marine Performance and Tommy at Chief about some previous work I had done. |
Originally posted by ssm-v1 I know that Innovation does hipo rebuilds. But I would do a 39 epoxy with a pair of merc.900s on #6 that should be good a high teen to 120 mph boat if I had the cash. Trout, I am between TX and So Cal and we have nothing down in TX but tumbleweed and cowboys:p :crazy: We own a trucking company so I can put the boat on a stepdeck and send it anywhere in the country...I just want the best motor for the dollar that won't break every time we go out or be a maintenance nightmare. |
Originally posted by T2x Whoa!!!!!! .....T2x Bora-Bora, huh? Post some pics for us less fortunate ones, please. "Plastic bravos" - :eek: |
How about Sterlings 850 ish ??? package with sixes ... oooooooooooohhhhhhhhhhhh boy !!!!!!!!!!!
Mike D. says 200 hours !!!:cool: |
1 Attachment(s)
Try the Total Marine Guys, Steve and Eddie, 954-649-9888.
The motors going in my 4300 Nortech were built for reliability, I'm tired of tinkering and just want to have a good time this year hitting as many poker runs as possible. 599 C.I. Dart [email protected]@4500 Idle.750rpms...WOT 5500. Lunati Pro race crank Oliver billet rods JE Forged pistons Dart pro 1 fully ported and hand polished heads crane hyd. roller cam and hardware custom 14qt oil pan custom built multi port FI 2000 cfm billet throttle body MSD ignition And a 1 year warranty, with proof of oil changes every 10-15 hours, which is what I do anyways. If I had the video of them running on the Dyno, I would put it on here for you guys. Jeff |
| All times are GMT -5. The time now is 08:04 PM. |
