Big and Heavy (hitch) Balls >
Old 08-11-2004 | 05:30 PM
  #41
CigBoat's Avatar
Default Re: Big and Heavy (hitch) Balls
Yeah its the stock hitch on a 2500HD
CigBoat is offline
Old 08-12-2004 | 12:35 PM
  #42
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Rippem, I completely understand the overkill, and ratings. I am an engineer by nature, and over-engineer a lot of what I do.
I just don't want anyone else to think that because they buy a 20K lb drawbar, and a 30K lb ball, that they can stick it in their 2" Class III reciever, and be safe & legal to tow the Space Shuttle behind their 1500 Chevy pickup with a 4.3L V-6.
Sydwayz is offline
Old 08-12-2004 | 02:58 PM
  #43
understand completely. With everything else forward up to snuff, I see couplers as the next weakest link. Think about the size of the mechanism and how much material is there...for the amount of work being done. Check out the "trailer trapper", it'll at least keep the tongue on the ball if the mechanism fails.
Rippem is offline
Old 04-07-2005 | 05:49 PM
  #44
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Bump. Have had several people ask me about this recently.
Sydwayz is offline
Old 04-29-2005 | 08:32 AM
  #45
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
One more update.
I have my Putnam Class-V hitch installed now. It bolted right to the factory holes, and actually tucks up closer to the bumper than the original. I have not towed with it yet, but will be this weekend.
Bill272 also spoke with GM directly about what happens to your tow rating on specifically the 2500 Avalanche when you replace to a Class-V hitch. According to the GM Regional Manager he spoke to, your Weight Carrying rating goes up to the 12K with the Class-V hitch. It does NOT raise the overall tow capacity of the vehicle. Are you going to get that in writing? No. Will it fly in court? Who knows. I am still sticking with the WD hitch (bars) even with a new Class-V Putnam hitch. The WD bars drastically improve towing.
Also check out:
www.equalizerhitch.com
Fully compatible with surge brakes as well.
Sydwayz is offline
Old 04-29-2005 | 09:58 AM
  #46
Bill272's Avatar
Brian,
Just to clarify, I was told that adding the Class V hitch raises the weight carrying rating to the 12000# rating of the truck, not the 15000# rating of the hitch. Along with the Putnam XDR I did get a 15K# 2" solid steel ball mount and the 30K# ball.
There's quite a bit of difference in weight between the class V and the factory hitch. I don't like to think of what I was towing with before (6000# ball and mount with an 11-12K# boat and trailer)
Bill272 is offline
Old 04-29-2005 | 10:50 AM
  #47
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Bill,
Thanks for clarifying. I adjusted my previous post.
Sydwayz is offline
Old 05-01-2005 | 09:19 AM
  #48
Strip Poker 388's Avatar
Rob
Mine does just fine
Attached Thumbnails Big and Heavy (hitch) Balls-chevelle-eng-element-bryant-eng-049.jpg   Big and Heavy (hitch) Balls-chevelle-eng-element-bryant-eng-051.jpg
Strip Poker 388 is offline
Old 05-01-2005 | 10:02 AM
  #49
US1 Fountain's Avatar
Ginger or Mary Ann?
Maybe I need to install one of these WD hitches. But luckly I can just put taller axle snubbers on to bottom out on the frame sooner to keep it level.
Pulls like a champ, tons of power down hill, tons of braking going uphill, steering is easiest ever, front tires turn 1/2 the speed as the rear tires too!
US1 Fountain is offline
Old 09-14-2005 | 04:22 PM
  #50
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
:d
Sydwayz is offline
