changing oil
Old 06-24-2004 | 01:23 PM
MitchStellin's Avatar
Default Re: changing oil
Trader, I would not have it any other way I did mine when they were out so it was a snap. Out the dip stick just doesn't seem to get all the oil, plus with most crap settling in the pan this will suck that first and clean out the big chunks of metal that are normal in a boat motor. Some are so big they plug the hose but most make it thru, I wonder where that metal comes from? Is this a by product of combustion? Maybe it is just normal
MitchStellin is offline
Old 06-24-2004 | 02:17 PM
mr_velocity's Avatar
If you have pre lubers there should be a quick disconnect fitting between the pump and the oil filter. Disconnect it and turn on the pump.
At least that is the way mine is rigged. Quick easy changes!!!
mr_velocity is offline
Old 06-24-2004 | 02:56 PM
OldSchool's Avatar
Must be "Change your oil week". I just finished doing both of mine and Drive fluid changes as well. Now I have to break the law and transport 7.5 gallons of used oil up the street to the garage!!
OldSchool is offline
Old 06-25-2004 | 10:32 AM
Mr. Velosity, thanks I will look into that for the next time.
G, that does sound like fun I will look for air fare, I called you yesterday??
trader1 is offline
Old 06-25-2004 | 10:39 AM
trader1 is offline
Mikey Likes It
4
03-29-2006 07:29 AM
Venomous
6
10-01-2004 02:46 PM
pondrocket
Fountain
5
08-09-2004 08:00 PM
PhantomChaos
08-13-2003 09:44 PM
