Best HOME-MADE vinyl graphic application solution.. >
Old 06-23-2004 | 09:16 AM
Chris288's Avatar
Default Best HOME-MADE vinyl graphic application solution..
going to be putting a intricate viny decal on the fairing and was wondering what the best application solution is.. been told a touch of bleach and water,,, johnsons baby shampoo and water,, windshield washer fluid..
Other problem is the masking tape over the top of the viny is VERY strong. was told to apply decal, let sit over night and spray the backing to loosen it up and pull off at a 45 degree angle..
Chris288 is offline
Old 06-23-2004 | 10:28 AM
Default Re: Best HOME-MADE vinyl graphic application solution..
Chris,
I do not recommend using the products you mentioned. Bleach? no way this will harm the adhesive in the decal. Ammonia in windshield fluid is bad for decals too. Soap and water can work but if you use too much soap or the wrong kind the decal will not stick or if you use too much water the decal will not slide. Either way now your decal is junk.
Use a product my company manufactures called "Sticker-On!" Decal Application Fluid. This proprietary formula allows you to slide and position your decals into place and then does not interfere with the bonding of the adhesive in your decal. We sell gallons and gallons to the Nascar guy's. I will be using some this weekend as I prepare my boat for the Catalina Ski Race!
Go to www.hardlineproducts.com any questions you can contact me personally.
Good luck.
Kevin Schulte is offline
Old 06-23-2004 | 10:59 AM
Chris288's Avatar
Thanks Kevin, I am very familiar with hardline products, they are all over my jet ski's... I'll just stop by walmart and pick up some sticker on.. thanks again..
Chris288 is offline
thedonz
07-11-2014 07:15 PM
GO4BROKE
04-13-2008 06:41 PM
buggyride
09-19-2007 10:21 AM
SeaWeasel
6
02-03-2004 02:51 PM
Intolerant1
09-25-2002 12:39 PM
