View Poll Results: Who makes the best blower/supercharger?
Voters: 372. You may not vote on this poll
#131
Originally Posted by JCPERF
How about EGTs?
More motor combos will also show more results, so we'll see in the future, but it's certainly better than anything we've tested, even out performs the quad rotor which already out performed the PSI. I'm very excited about this SC, it's my baby
Thanks,
Dustin
#132
Originally Posted by Byrdman
I like boost....some of my people do not like boost and give me horse crap excuses...I am getting very tired....what is the most boost you would like to see in a boat motor...of course it has to live......not blow up like some of this boards biggest talkers have done.....the motors must live in a boat....all the big boys here blow up....then blame it on something else.....when it was just a misfired gamble of timing fuel and boost....nice
#133
VERY nice stuff Dustin, I can't wait to get a pair of them in the new boat. I talked to Mark down at the shoot-out and I guess I will have arm wrestle Richie to get the first set.
Mark seemed excited about them as well. How is the Throttle body coming, I heard that KE was also working on a pretty slick one for this set-up.
Congrats and I can't wait to get a pair.
#134
Originally Posted by Whipple Charged
Rob,
The tensioner is bolted to the front of the SC front cover via a billet 2 piece bracket that goes to 4-points on the front plate and around the drive snout. It was run with 8mm setup, with the idler off the drive snout. Used a blower shop 6.9" drive snout, coupler and idler pulley. So it will work either way, but the serpentine setup is very sexy!
As for the intercooler, the SC has a 2" plenuem below the triangle discharge port, we use the bottom plate to direct the air where needed for proper distribution. The entire bottom is open to the intercooler. The one we used is the MOAC, which is 1" thicker than what you have and it has 2 more inlet/outlets. Works really good with this plenuem on the bottom, allows it to adapt to a standard 4.1" roots opening, modified roots at 5" or a Whipple intercooler, single core or our double billet which is 8" wide.
Thanks,
Dustin
Thanks,
Dustin
Thanks Dusting for the reply
2 inlets and 2 outlets in just one core? I guess you are trying to get more water flow thru it?
Rob
#135
Originally Posted by mikes280
would you like to see my dino sheets on a 540 with a single 3.3 whipple try 1067 hp at 5700 and 1128 ft. lbs. one 1180 cfm carb
WHAT COMPRESSIOM AND WHAT GUTS ARE IN THE ENGINE
#137
I think I'm going to have to wait to see your paint job, I heard it was kinda boring
I got you on my list still, looking at it right now, your number 3 and 4, sadly, you can't be 1 and 2, because I'm 1 and 2
I think to be fair, I'm going to have to send numbers 3,4,5,6 all at the same time, you can have 3, Richie can have 4 and 5, and you get 6. Everybody is equal
Heard the boat looks awesome, can't wait to see it.
Thanks,
Dustin
#138
Rob
Rob
Yup, were passing far more water, it's also going in on the bottom and exiting the top, which helps take any air out of the system during low psi water flow levels. It's broken up into 4 chambers now vs. 2 previously. There are some other changes as well, larger air passages, smaller water ports, more fpi on the water side. Overall, it has lower psi drop and increased cooling. This of course depends on the boost level, but it's better.
Dustin
#139
Thanks,
Dustin
#140
Originally Posted by RichardCranium572
Boost is just a restriction of airflow
