View Poll Results: When I change my oil filter.....
My engine and bildge look like an oil field
10
6.37%
I'm pretty careful but still drip more oil then I'd like
45
28.66%
I put rags around the engine to catch the spill
59
37.58%
I never spill a drop
54
34.39%
Multiple Choice Poll. Voters: 157. You may not vote on this poll
For those that change your own oil
#41
Use the plastic bag method but also slip a large ziplock bag over the filter for containment when removing. Zip it, let it down in the plastic bag.
When adding new oil I use the screw on hose nozzle with a twist closure, place the quart upside down, open the valve and also take a knife and slit what would be the bottom of the plastic container to let air inside. A few seconds and each quart is emptied.
#42
theres a 5 dollar cure for splillage on inverted oil filters. Go to the auto supply store, buy a 1/8 pipe 45 degree male to female elbow, a 1 inch male/male nipple, a 90 degree female to female elbow and a pipe plug, all brass, some sealer or teflon tape and you're all set. Remove the oil filter adaptor after marking a spot to drill that gives you clearance to access the pipe plug. Drill and tap the adaptor to accept the 45 fitting, then connect the nipple and the 90 so the 90 points downward. use tape or sealer at all connections including the plug. Before removing the filter next time, remove the plug and drain the filter before removing it.
#43
Re: For those that change your own oil
Hello, just like downtown says, wrap a few plastic bags around filter and spin off. pre loosen before you bag that bad boy. I have had great luck with this.
as for the engine oil, I SUCK it out through dip sticker.
Have at it. B3
Have at it. B3
#44
I have used this oil filter drain kit for aircraft engines. It will fit on the filter for the 500 EFI. Sporty's Pilot shop online. Works great!
http://www.sportys.com/acb/showdetl....roduct_id=5734
#48
Dont make it so difficult, a few minutes before you drain the oil just punch a couple holes in the top of the filter let it drain back down and viola' no fuss no muss, no need to buy anything.
#49
Did anyone else notice that Troutly, or at least his screen name, appeared on the home page that he made a post at 7:38 am this morning, yet the post did not show up on the page?
Wonder if it was automatically deleted by the mods or if someone is somehow using his screen name. I checked it three times. It clearly said Troutly as the last post on this Thread, but you click to the last page and no post by Troutly was there.....
#50
Originally Posted by Skypirate
Troutly,
Yes, I have 500EFI's. It will also fit all automotive replacement filters. I use mobil 1 filters.
I did notice that Sky responded to him at
5:35.
OSO in the big house?
