HELP ! Need info on changing problem (freezing) fuel line on excursion . who has it ? >
Old 01-31-2005 | 07:44 PM
Default Re: HELP ! Need info on changing problem (freezing) fuel line on excursion . who has it ?
OH, plumbers crack , your right too , there is a tiny screen in the tank ,On a pump,(E series only) and the water beeds up and freezes . The "DIESEL TECH" at ford didn't know this ... I almost got into a fist fight with him before he realized I was right ! After the 3rd time they towed the truck( 100 miles each time ) he finaly listened and dropped the tank ,cleaned the tank, and the screan and pump that he said was not in there ...... He said I was an idiot for thinking there was a drain on the tank till I showed it to him ! Too bad all tanks don't have drains .....
(The pickups don't , only the E series vans do .)
boot is offline
Old 01-31-2005 | 07:49 PM
BryanTuvell's Avatar
Donzi33ZX
I recommend just having her towed and checked out, my 2001 7.3 was terrible if the heater was not plugged in below 20 degrees.
The new 6.0 HCFM filter also acts as a warmer, which I am not quite clear on, (just read my book tonight). It's location sucks for changing, but two filters are better than one.
I will attest my 6.0 started after many long sub 0 nights in Ohio, we had no electric at Xmas and she was fine.
The book also says to ensure you above 1/4 tank a gas to avoid excess air in the system.
WARNING, be sure of what your doing opening any part of the fuel line on the 7.3.
Bryan
BryanTuvell is offline
Old 01-31-2005 | 08:38 PM
SeaRay Jim's Avatar
One word, Stanadyne!
SeaRay Jim is offline
Old 01-31-2005 | 08:57 PM
Steve Snider's Avatar
Wow....Sure glad I moved from Northern Illinois to South Florida. My 02 Excursion Diesel starts everyday..........I do remenber the problems with diesel engines when it dropped below zero. Always add diesel fuel additive no matter what the make.
Steve Snider is offline
Old 01-31-2005 | 11:27 PM
fatdaddy's Avatar
I use the additives year round.
fatdaddy is offline
Ran-Dom 32
0
04-19-2005 01:41 PM
BAD-HABIT
21
06-16-2004 10:52 AM
