turbo charger Hustler?
#91
Originally Posted by License To Thrill
Just talked to Leon. He said the motors are 664ci and will make 3000hp each. I know the boat he's building but he said not to talk about it. I CAN say he's going for the propeller speed record of 225mph.
He's rebuilding my motor after it blew up last Nov. I was running 105 when the oil pump malfunctioned. My boat is a 24' Carlson air-entrapment monohull.
#92
Originally Posted by SCARABJ
Rik you are correct eickert got that setup from carson B. and most parts are from the gentry setup.. eickert built these the way hustler wanted them.. he is designing a new twin turbo setup but it probably will not be COOL because it does not have 40 foot of tubing and a intercooler in the cabin
Of course it would be best to have both, but I think the engine room will look a lot better when the polished tail pipes get installed. That should break the colors up some.
As for all the plumbing stuff, less is more in a boat.
#93
Originally Posted by Ron P
All I know is, I've been to 115 on a 388 with 675 KE and Arnesons. 130 from 850s doesn't sound that far off, if you have the balls for it.
I'm sure RIK knows him.
#94
Originally Posted by NOBODY
The all white hustler from table rock has 850 K E's and ASD 6's and it runs a little over 100.
He has been over 100, not to say that it will not go faster just that he has been over 100.
The 388 with the Eickets does run 115, spoke with those guys today and they confirmed that.
Matt Shade has another 388 (LOTO) with Cobra 750's that has been 110 before. Some different propellers and the boat will go faster.
Rolf @ Proroc played with propellers on the one with Eickert 675's and got it to go that fast. 33" Pitch propellers @ 5400 rpm. The others are running less pitch.
#95
Originally Posted by Rik
That is Tim Friend who has a white 388 with a set of 572's and Vortec blowers. Those are not KE motors, rather a set of GM 572's with the Vortec's added I was told.
#96
I belive that Tim had Eickert fix some problems with them when they were first put in the boat. There was a water pickup problem that overheated the engines I was told.
#100
When he recieved his, there were no rear strakes. He must be good as he made a mold of his old boat and glassed the new ones on as they were original.
He will still need to remove some of the strake to get the boat to settle down at speeds over 100.
What happend with your glue?
