turbo charger Hustler?
Old 02-24-2005 | 09:32 PM
  #71
Strip Poker 388's Avatar
Rob
Default Re: turbo charger Hustler?
I wonder how Paul Plaff Turbo motors are coming ??
Strip Poker 388 is offline
Old 02-24-2005 | 09:44 PM
  #72
SCARABJ's Avatar
AKA NORTECHJ
Originally Posted by bob
I think they are on their way to KE's dyno this week.
they go on the dyno fri or sat.. john pompi took them out wed and sent them to eickert..
SCARABJ is offline
Old 02-24-2005 | 09:47 PM
  #73
Rob
They where telling everybody it made 850hp
Old 02-24-2005 | 09:58 PM
  #74
Bling Bling
Originally Posted by JCPERF
The wave of the future
Could not of said it better!!!
blingbling is offline
Old 02-24-2005 | 10:01 PM
  #75
Bling Bling
Originally Posted by Sean H
i want one now, screw the future....
Carson Brummett 626-792-6410.
Old 02-24-2005 | 10:30 PM
  #76
Is the slight turbo lag a thing of the past now with all the tech stuff???
Byrdman is offline
Old 02-24-2005 | 10:41 PM
  #77
Bling Bling
Carson has been doing these types of motors for years. About a year ago he finish up a new project twin turbo fuel injected 500" motor that pulled 1668hp at 20 lbs of boost pressure, and torque was also right there. On pump gas just over 1200hp. There finished off like nothing you've ever seen, beautiful to say the least. Rick Bowling has two he is installing in his 37 talon, but I think he has a bit more cubes. I can't say enough about the finish, quality, and reliability of this set up. A flip of a 3 position switch changes everything from pump, av, and race gas settings. Here's a major Plus, the noise level is great to. I would have to say these motors are the best poker run motors a person could ask for. Time to get off Carson's nut sack, hope this helps you out.
Old 02-24-2005 | 10:44 PM
  #78
Bling Bling
The ones I've been in I felt no lag. But then again the ones I,ve been in were all over 14lbs of boost.
Old 02-25-2005 | 12:16 AM
  #79
BigSilverCat's Avatar
Originally Posted by Steve Schmidt
yes, a 358 big block. big bore, short stroke ex open class engines. smooth as silk and never stops making power. just wish I had a bigger boat.
Speaking of small stroke big blocks with turbos, here's a dyno sheet of a 4.500 bore 3.75 stroke motor my engine guy built a few years back for a 24 eliminator cat with #6 drive. On this dyno pull it was running the injector map rich on high rpm, that's why it was losing power early. Re mapped It and then made 2146 @ 7500 on race fuel.
BigSilverCat is offline
Old 02-25-2005 | 12:33 AM
  #80
Rob
I like how the software computes your average ,cool
Who is your engine guy?
Rob
